For the cross member
I used a set of chisels on either side of the sombrero's (leave the bolts in a few turns so it doesn't fall
Many people have had luck with 2 and 3 jaw gear pullers
for the crossmember, put a block of wood on top as close to the end as you can get it and pound on it with a 3lb sledge hammer... the wood will prevent the hammer from denting the crossmember and it will let go.
use a chisel to cut the rivets on the ball joint.
on the steering, keep everything except the old steering box, the control valve and the cylinder... basically just discard anything with a hose attached to it.
you will reuse the pitman arm, center link and the tie rod assy's... of course you will need new tie rod ends and idler arm.
It's Borgeson. It is a replacement for the power steering system used in C3's. The C3 system uses a manual steering gear (box) and the "power" steering is provided by a hydraulic ram that is connected to the drag link and the frame.
The Borgeson box has the "power" steering built into the steering gear like most other power steering systems. It eliminates the hydraulic ram which tends to leak in these old cars.
Thanks, I haven't been on the C3 forums in quite a while and had not heard of this Steering upgrade.
yeah i did that, it too me 5 mins, lol . Been looking at it for a 1 week.
Thanks for that pic of the box, a pic is a 1000 words .
I grinded of the a arm rivits. But i need to go down the hardware shop to buy a punch, ot punch then out.
Also a side note about the por -15. I already have the 2 paints. After sand blasting ( which i am paying someone to do it), how long would be the max safe time till paint before rusting, 2 days? Also should i buy any of that cleaning stuff, since i dont know who handles it and how, when sand blasting.
Reason: por -15 added
