Vacuum Pump
Old Dec 7, 2012 | 07:39 PM
Stingray-Jer's Avatar
Stingray-Jer
Default Vacuum Pump
I am having some vacuum issues (headlights) on my BB 68 due to the big cam. The shop has recommended a vacuum pump.
Can anyone recommend a particular pump. I am thinking that electric is the way to go?
Thanks everyone.
Old Dec 7, 2012 | 08:41 PM
TimAT's Avatar
TimAT
No clue on a pump, but I do agree electric would be the way to go- no parasitic load when it's not running.
Just curious, how much vacuum do you have? I have 12-13" at idle and the lights are a little slow, but no problems other than that.
Old Dec 7, 2012 | 08:54 PM
Stingray-Jer
I don't know what the actual reading is. I have had the shop trying to get the lights going and work out all the bubba from the vacuum line system.
As a last resort I am going to put a pump on.
Old Dec 7, 2012 | 09:19 PM
TimAT's Avatar
TimAT
Willcox has a vacuum and troubleshooting diagram. I think it's online at his site.
Old Dec 7, 2012 | 09:24 PM
SuperBuickGuy's Avatar
SuperBuickGuy
I have a hella vacuum pump and comp cam vacuum canister. Honestly, I think the biggest "fix" was the canister and dual diaphragm booster.
Old Dec 7, 2012 | 09:36 PM
Stingray-Jer
What type of issues were you having?
I don't have power brakes on my 68.
Old Dec 7, 2012 | 09:42 PM
Stingray-Jer
Thank you sir. I previously downloaded the diagram. I will download the guide.
Old Dec 7, 2012 | 10:09 PM
jcloving's Avatar
jcloving
Harbor freight has a good pump.
Old Dec 7, 2012 | 10:26 PM
Stingray-Jer
For a Vette??
Old Dec 7, 2012 | 11:07 PM
7T1vette's Avatar
7T1vette
You really shouldn't need an auxillary vacuum pump. But, the system does need to be well sealed and the components in it need to be in good shape. The most common 'faults' with the vacuum systems are a bad check valve, leaky headlight relays, and...if you have the vacuum wiper door...bad solenoid switch (on backside of tach) and/or defective wiper safety park switch (under the right-side wiper).
Old Dec 8, 2012 | 12:40 AM
SuperBuickGuy
If I was in stop and go traffic, I'd have one stop with vacuum assist, the next without.... it was a bit annoying. Also, on tight courses, I'd rarely actually have power brakes after the first attempt to stop.... and forget about it if it was a "ride your brakes through the course" course, it would be manual level of effort all the way.... kills elapse times.
I have a pretty radical (for the street) cam.... 280/280, 108 LSA .550 lifts (SBC)
Old Dec 8, 2012 | 09:36 AM
C6DuffMan's Avatar
C6DuffMan
I would have to agree that an auxiliary pump shouldn't be needed of the system is sealed well. The accumulator tank will store vacuum until you need it. Even with a big cam, you will pull some decent vacuum during normal driving and that will be stored in the accumulator, unless it all leaks out.
I have a big cam in my 454 and it takes a few minutes after start up to build enough vacuum to pop open the lights.
Old Dec 8, 2012 | 10:38 AM
Mike Ward's Avatar
Mike Ward
Thanks everyone.
I wouldn't recommend a vacuum powered pump.
Old Dec 8, 2012 | 11:40 AM
joewill's Avatar
joewill
Yes, i would more think you have a leak instead of blaming your cam.
Your mechanic is a little questionable also recommending an unorthodox solution by suggesting installing a big ugly loud vacumm pump, instead of doing diligent troubleshooting and finding a cracked hose.
put a gauge on your canister tank and do a leakdown test after shutting off your engine.. after plugging the appropriate lines.
what else is there besides electric pumps? some hideous belt driven thing?
Old Dec 8, 2012 | 11:48 AM
SuperBuickGuy
uhhhh.... isn't a sbc little more than a vacuum pump?
Old Dec 8, 2012 | 12:45 PM
Mike Ward's Avatar
Mike Ward
Ya, they just plain suck. BBCs suck even more.
Old Dec 8, 2012 | 12:52 PM
TimAT's Avatar
TimAT
Really, they're all just convertors.
They convert cold air and fuel--
To hot air and noise
To Vacuum Pump
Old Dec 8, 2012 | 05:23 PM
SuperBuickGuy
Last I checked, they were hazardous waste disposal devices. They provide heat, music, food for the trees, and work - all while ridding the planet of a toxic waste.
Really, we do the planet a favor by running our cars
Old Dec 8, 2012 | 08:38 PM
Stingray-Jer
Thanks Joe.
Old Dec 8, 2012 | 09:32 PM
Dave J's Avatar
Dave J
Hey Jer...........
I sure wish I had more time before your car was picked up for it's journey to it's new home, I could have checked out your vacuum system for you.
IMHO, are we sure the messed up hose routing has been corrected, the relay has been tested for proper function, and you're getting good control vacuum from the switches? I would like to see the results of these issues before I would even think about a separate pump. A decent hand vacuum pump tester is much less than more drastic measures.
If you would like, I can talk you through these, and get you a routing diagram if you don't already have one. Let me know........
Good luck my friend!
