Rack attack vs steroids?
Old Dec 8, 2012 | 10:08 PM
CWerner's Avatar
CWerner
Default Rack attack vs steroids?
Opinions on which is better or are they the same?
Old Dec 8, 2012 | 10:11 PM
Corey_68's Avatar
Corey_68
Steeroids is what most of us are running but the racks have nominal differences.
Old Dec 8, 2012 | 11:49 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
Very little difference. I'd go with the cheapest price.
Old Dec 9, 2012 | 08:07 AM
Gordonm's Avatar
Gordonm
I have a Steeroids and have installed Rack Attack and they are both very much the same. Just very minor differences in the tie rod ends. As said whichever one is on sale at the moment.
Old Dec 9, 2012 | 08:45 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Have had steeroids for quite a while and have been very happy with it. Makes the car drive like a new one. To get the full benefit, I rebuilt the front suspension while I was in there. Very happy with my choice.
Old Dec 9, 2012 | 10:36 AM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
I don't have any experience with any of the r&p systems on the market, but I am thinking about going with the Flaming River system. It seems like the other systems have a lot of play in their mounting brackets. I like the fact that the Flaming River rack is solidly mounted in a frame-to-frame cradle, which should eliminate any play.
http://www.flamingriver.com/index.ph.../s0001/FR312PW
Old Dec 9, 2012 | 11:35 AM
Raphiki's Avatar
Raphiki
I've been a leery of Flaming River since I attempted to install one of their steering columns. Nothing fit like it was supposed to. My only concern about their R&P system is that, while the other manufactures use racks that are common to GM cars, FR makes their own so that if the rack should go bad replacement could be expensive or impossible if they quit making the system. That and they are about $300 more than the others.
Old Jan 1, 2013 | 10:39 PM
509 rat's Avatar
509 rat
Default good idea
I agree with that one, I want to run the vansteel tube type upper and lower arms with the coilvers double adjusters.then maybe a 5 link rear set up, mine will be for sreet and auto cross, maybe some track days.
Old Jan 1, 2013 | 10:50 PM
509 rat's Avatar
509 rat
Default check this
I think that you cant ajust bumpsteer on the flamming river.but check it out.plus you
have to make your own arm to connect to the column.
Old Jan 1, 2013 | 10:56 PM
509 rat's Avatar
509 rat
one more thing, its a good idea to. rebuild pump before install
Old Jan 2, 2013 | 08:59 AM
CWerner's Avatar
CWerner
I went with the FR Rack set-up. I'm not sure what you mean by you have to make your own arm to connect to the column. I've been assured its a direct bolt in.
Old Jan 2, 2013 | 12:51 PM
540 vette's Avatar
540 vette
I bought a set up like that for my 67 GTO. The cradle mounts to the spot where the idler arm would bolt up and the steering box bolted up. Bolted right in with no drilling or welding. Looks factory.
Old Jan 2, 2013 | 10:31 PM
509 rat's Avatar
509 rat
Default that would be good
I thought it was just the rack and thats it.
Old Jan 3, 2013 | 09:48 AM
Hale584's Avatar
Hale584
I put a Flaming River unit on a '71 Camaro.....lost a lot of turning radius. It was okay because I had a spool in the rear end, but IMHO I don't think it would be very good for a regular street driven car.
Just my thought's,
Glen
To Rack attack vs steroids?
