Power window conversion - experiences?
Old Dec 9, 2012 | 01:57 PM
ChrisMiami's Avatar
ChrisMiami
Default Power window conversion - experiences?
Hey Guys,
I am considering Eckler's power window conversion kit and I was wondering if anyone's had any experience with either the specific kit or with changing a manual window to power?
I have to rebuild the doors anyway, so I figure why not upgrade!
Thanks!
Chris
Old Dec 9, 2012 | 02:44 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I would make sure the regulators are the US made regulators.. that would be a must. The recent batch of the imported ones have the wrong rollers on them.
I would also make sure the motors are the square type and not the rounded ones.
I put all this in a cart on my site with the US Regulators to see where it fell..
Door Window Switch With Pw 68-82 2x
$39.98
Power Window Motor New LH 58-82
$80.00
Power Window Motor New RH 58-82
$80.00
Power Window Regulator. Less Motor LH 68-82
$158.99
Power Window Regulator. Less Motor RH 68-82
$158.99
Power Window Wire Conduit. 2 Required 68-81 2x
$27.98
Harness. Power Window Complete 76 Early
$131.88
Power Window Relay.68-82
$23.95
Sub-Total: $701.77
Use the current sale coupon and you can save even more off the price.
Old Dec 9, 2012 | 04:17 PM
zwede's Avatar
zwede
I did this on my '71 a few years ago. Easy conversion. In my case my manual regulators were worn out so since I had to replace them anyway I just converted to power.
I bought original (used) regulators on ebay. New motors (unfortunately I could only find Chinese ones). New wiring harness, switches, relay & fuse. I also replaced the door panels for other reasons so that worked out well. The non-PW center console is marked on the bottom for the switch cutouts.
Edit: This should be added to Willcox's list:
http://willcoxcorvette.com/product_i...ducts_id=27531
Old Dec 9, 2012 | 05:47 PM
0Willcox Corvette
Former Vendor
He didn't post a year but I just looked at his old threads and it seems to be a 73. So the harness would be this one.
http://willcoxcorvette.com/product_i...ducts_id=26054
Old Dec 9, 2012 | 07:03 PM
ChrisMiami's Avatar
ChrisMiami
Haha - nope. In my user tile, it says '69 Coupe' (maybe those can be turned off?). Link there to pics of the car, too.
My doors have to come completely apart and I think I have to address some issues with the outside skin and put new guts and interior panels on them. So yep - my reward is gonna be power.
Thanks for the input - glad to hear it's not an impossible task!
Chris
Old Dec 9, 2012 | 10:00 PM
LemansBlue68's Avatar
LemansBlue68
I did this on my '68 and am glad I did. It was relatively easy. I pieced mine together over time with new and used pieces that I found at swap meets, Ebay and Corvette vendors as well as 2 rebuilt Delco motors from a local auto parts store.
The hardest part may be drilling the holes in the doors for the wiring harness. I had the doors off at the time so it was easy. I'm not sure how you'd do this without removing them.
Use the AIM to guide you through the harness routing, hole location, etc. It helped a lot for this job.
To Power window conversion - experiences?
