76 steering column
Old Dec 22, 2012 | 01:28 PM
mlw's Avatar
mlw
Cruising
Default 76 steering column
I am attempting to assemble the column after installing a new key switch.
When I compress the lock plate the shaft wants to pull out so I can not get the compressor to move down on the threaded rod putting enough force on the plate.
Old Dec 22, 2012 | 05:21 PM
TimAT's Avatar
TimAT
IF you're working on a telescopic column, you need to install a bolt to lock the upper shaft.
Old Dec 22, 2012 | 06:33 PM
DUB's Avatar
DUB
Actually installing an allen set screw works great for me. It allows the set screw to thread down into the shaft and hold down the pin with tension...and still allows the lock plate suppressor to be threaded on the shaft easily.
DUB
Old Dec 22, 2012 | 08:24 PM
noonie's Avatar
noonie
DUB
Or this.
Old Dec 23, 2012 | 03:14 PM
Jim Shea's Avatar
Jim Shea
You need a 5/16-18 UNC set screw or a #20 allen screw to lock the upper shaft.
Jim
Old Dec 23, 2012 | 04:47 PM
'75's Avatar
'75
This tool works great, the center bolt screws into the shaft and locks the telescope and also depresses the lock plate.
To 76 steering column
