Question about 71'
Old Dec 26, 2012 | 10:49 PM
Cdevette's Avatar
Cdevette
2nd Gear
Default Question about 71'
I've noticed pictures of early 70's late 60's with mysterious "bumps" above the front head lights in the fiberglass. The reason I ask is My father passed down a 71' driver that's in great shape with these same "bumps" in the fiberglass. I would say 6 or 7 across the top of the each light. What are they from....I remember displaying the car with him at shows when I was a kid and they weren't there then. Just wondering......
Old Dec 26, 2012 | 11:18 PM
champs65's Avatar
champs65
They are from deteriorating rivets on the header bar.
The header bar is a metal support which runs from side to side and has a bonding strip riveted to it. The nose then glues to header bar/ bonding strip. Over time the aluminum rivets corrode due to contact with the steel header and expand. The end result is the series of round spots that you see.
Often this is evidence that the front end hasn't been hit, replaced, or repainted or otherwise screwed with.
Old Dec 26, 2012 | 11:28 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
It is an issue with the chrome bumper C3s. The reinforcing bar that the headlamps hang from is two pieces of steel fastened together with aluminum rivets. One of those pieces of steel is bonded to the underside of the hood surround.
The problem is the aluminum rivets corrode when moisture (even humidty in the air) reacts with the aluminum and steel pushing the paint up into a bump/bubble. All remnants of the aluminum have to be removed to prevent the reoccurrence of the corrosion.
The best fix is to remove the steel reinforcement, remove all of the aluminum rivets, then rebond the upper reinforcement bar to the fiberglass and glue/epoxy the two pieces of steel together, then repair the fiberglass.....not an easy task
Another method used is to grind out the rivets and fill with glass but with that type of repair the results over time are mixed.
You can also just leave them alone as it's a sign of an original front clip/paint.
Old Dec 26, 2012 | 11:47 PM
gbvette62's Avatar
gbvette62
Typical Corvette problem. Around the mid 70's, Chevrolet stopped using the rivets and bonded the surround reinforcement in instead.
If you want to eliminate the bumps permanently, you need to remove the rivets and bond the reinforcement in.
Old Dec 27, 2012 | 01:51 AM
Cdevette's Avatar
Cdevette
2nd Gear
Thanks a bunch..new to the forum but I'll be around for a while with the vette in the 2nd generation now..thanks again...
Old Dec 27, 2012 | 04:08 AM
7T1vette's Avatar
7T1vette
Or, like me, you can just leave them alone until you have a problem with the paint above those rivets. As mentioned, having that 'condition' proves the nose is original and undamaged.
Old Dec 27, 2012 | 03:32 PM
Dan H.'s Avatar
Dan H.
St. Jude Donor '17
My 71 also has them. When I inquired about them, much like your doing now, someone called them "a badge of honor". I liked that and haven't thought about them since!
Old Dec 27, 2012 | 04:36 PM
oldgto's Avatar
oldgto
I`m also new to Corvettes. We bought a 71 with front fiberglass damage. The front clip we bought from another car had the "rivet bumps". I followed the great advice of Willcox Corvette.... I ground the rivet heads off, pulled the steel header off, then dug out the remaining pieces of the rivets. Then I glued the header back on, with extra glue into the holes left by the missing rivets, and a board with a bunch of clamps. The board acts to push the fiberglass bumps back down.
Old Dec 28, 2012 | 11:27 AM
nelson007's Avatar
nelson007
Hello oldgto,
Do have a picture after it was finished? I am going to be doing the same process soon.
Thanks,
Nelson 007
Old Dec 28, 2012 | 11:41 AM
STL Zombie Hunter's Avatar
STL Zombie Hunter
St. Jude Donor '13
I have the same issues on my '72. Glad to know something was still original on her and not 'Bubba-fied'.
Old Dec 28, 2012 | 03:19 PM
Ironcross's Avatar
Ironcross
Before and after, approximately 38 in two rowes
Old Dec 28, 2012 | 05:13 PM
oldgto's Avatar
oldgto
Originally Posted by nelson007
Hello oldgto,
Thanks,
Nelson 007
Here it is after paint. I got the bumper on, but still need some headlight parts before I get those in.
I dug my rivets out from the bottom, so there was no surface damage to repair.
Before.....
And after.....
To Question about 71'
