C3 headroom variance
Old Feb 19, 2013 | 03:04 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
A tribute to the C-3 and its ability to accept upgrades
Glad you liked the drive and look forward to hearing more about your future changes.
Great guy, great car, great combo.
Enjoy.
David
Old Feb 20, 2013 | 11:28 AM
DJmaya's Avatar
DJmaya
Last night I checked the T tops to see if I could improve my headroom.
The good news is that the under cover is easily removable. The is just 1 screw and the rest is some time of Velcro like plastic clamps.
The bad news is that at some point the plastic "velcro" was glued together and I probably will not be able to separate this without doing damage to either the the clamps of the T-top under cover.
Also upon close inspection, it seems that removing the under cover will leave a lot of protruding things exposed and look quite ugly and somewhat dangerous to the skull.
Of to the next solution.
Old Feb 20, 2013 | 11:51 AM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Holy Cow David, I didn't use any glue on the T-Top covers so not sure how or where that came from. The velcro would/should have been enough to hold that in place so not sure why the glue would have been used. Those tabs are plastic and you could get inbetween them with a flat blunt object like a large screwdriver. Those Velcro peices are sold by several suppliers and they are rivited to the covers. I did replace them on my 71 Sparty, but not on the 77. I think you can get them off without damage though.
Any luck getting anyone to send you details of removing the lower rails? I think that would buy you at least three inches. Or maybe consider a later model seat, Ihear they are shaped differently and may be lower profile. Just ideas how to get your bum down lower.
Good luck David.
David H.
AllC34Me
Old Feb 20, 2013 | 01:40 PM
Roco71's Avatar
Roco71
As I mentioned in another thread the previous owner of my car removed the rear mounting brackets from the tracks to gain head room perhaps an inch.
Old Feb 20, 2013 | 02:50 PM
briankeery's Avatar
briankeery
I know you said you weren't a fan DJ, but if you know someone who has a glass top you could set in place to compare headroom, you might be pleasantly suprised without any other mods.
Old May 2, 2013 | 03:22 PM
81$$pit's Avatar
81$$pit
Originally Posted by qwank
just buy the one you like better, you can always modify the seat tracks and lower the seats or do something else to make more room. Maybe the black interior has old, worn out seat foam.
I agree. with my old 2" bolsters and 31 yr old seats I fit fine in my 81 but last night put in new seat foams and new leather and now my head sticks up about 2-3" above the windshield but did have to crouch down a bit before with the TTOPs on. I think I will have to break them in now before I go tops on.
Old May 2, 2013 | 03:26 PM
81$$pit's Avatar
81$$pit
do you have more PICS of your car qwank?
like the wheels in your avatar. Same looks I was going for.
I was thinking black side pipes too since my inside is now flat black and my engine compartment.
maybe stinger hood as well with black satin stripe .
