C3 headroom variance
Old Dec 30, 2012 | 01:46 PM
DJmaya's Avatar
DJmaya
Default C3 headroom variance
Hello gentlemen,
I am looking to purchase my first Corvette. I have decided to go for a 62-63 T-top manual.
I found 2 for sale yesterday at a dealer near me so I decided to go test drive them.
Now the problem is that I sat on the first one and I had no head room. I was very disappointed. I was thinking I was going to be stuck with a bubble window. I do fit on the 78-82 C3.
However my wife convinced me to sit on the second 72 C3 and surprisingly it was much more spacious.
I asked the dealer why they were so different, and he said the second one has all the bells and whistles including the aero chairs.
I have been trying to find more information about this chairs and cannot find anything.
Here is a picture for the first car (I love this car but I don't fit on it)
and a picture of the second car (I fit on this one but hate the color)
The only visual cues I see are the direction of the pattern in the chair. The car i fit on has leather chairs. and the armrest is different.
I would appreciate any feedback to figure out why there is so much headroom difference and how to tell if i am going to fit on a car or not without sitting on it.
Thanks a lot guys and happy New Year!
Old Dec 30, 2012 | 03:08 PM
69FASTFUN's Avatar
69FASTFUN
The first one does not have tilt and teli wheel where the second one does. That makes a big difference also how tall and how much you weigh makes a huge difference
Old Dec 30, 2012 | 03:24 PM
Alan 71's Avatar
Alan 71
Hi DJ,
I believe the seats in the cars are the same.
There was NO significant difference in the seats within the 68-72 model years. Only in the seat cover pattern
It looks to me like the black car has had the seat covers replaced more recently and the seat foam was replaced too. This makes the seat bottoms more 'puffy' and MAY cut down on headroom a bit.
The arm rest in the black interior is an aftermarket item.
My bet is that the seats in the blue interior have had the rubber seat back bumpers removed which allows the backs to tilt back further and gives more headroom. Many people did that over the years. Compare the rake of the seat back to lock pillar in each picture.
Regards,
Alan
AERO CHAIRS....that's a new one!
Old Dec 30, 2012 | 03:26 PM
DJmaya's Avatar
DJmaya
I am confused. How does the tele tilt wheel make a difference on how close my head is to the roof? And how does my weight and height make a difference from one car to the next? It is not like i an getting taller on one car and shorter on the other.
Old Dec 30, 2012 | 03:31 PM
DJmaya's Avatar
DJmaya
Allan, thanks for the reply.
I fit on the black interior. I do not fit on the blue interior.
Old Dec 30, 2012 | 03:35 PM
Alan 71's Avatar
Alan 71
Hi DJ,
I would then look for modifications to the seat tracks or modification in how the seats was attached to the track.
Same seats.... honest!!!
Regards,
Alan
Old Dec 30, 2012 | 03:36 PM
jnb5101's Avatar
jnb5101
i don't see the seat position release ball in the black car. it may be the picture, or the seats may have been bolted to the floor after the mounting rails were removed. i removed the rails on my coupe for just this reason, and i also did not install the headliners in the t-tops. gained about 2 inches of headroom.
Old Dec 30, 2012 | 03:48 PM
U17's Avatar
U17
Huuummmmm ... Never noticed that problem.. and I'm 6'1 ... could be I never put the tops on....But I've only had the car 14 years....
Old Dec 30, 2012 | 04:05 PM
briankeery's Avatar
briankeery
Does the yellow car have glass tops on it? All things being equal, having glass tops instead of fibreglass tops would equate to an extra 2 inches at least.
Old Dec 30, 2012 | 04:09 PM
DJmaya's Avatar
DJmaya
-deleted-
Old Dec 30, 2012 | 04:10 PM
qwank's Avatar
qwank
just buy the one you like better, you can always modify the seat tracks and lower the seats or do something else to make more room. Maybe the black interior has old, worn out seat foam.
Old Dec 30, 2012 | 04:20 PM
marshal135's Avatar
marshal135
Veteran: Marine Corps
Sir:
I'm 6' and 230lbs.
I can't do anything about the 6' part but the 230lbs is definitely my fault
I have a '68 which has the tightest interior of the C-3's and I fit.
I have to be careful to sit first on the seat and swing my legs in/under the steering wheel or I loose a portion of my quad area on the steering wheel.
I have a telescopic wheel only. Tilt was not avail till the following year.
I'm going to guess here and say the seats in the second pic have had a thinner seat cushion installed under the blk vinyl covers.
Maybe PO had same problems w/ fitting in drivers seat when the t-tops were in place?
A custom upolstrey shop could have fitted those seats with thinner foam. Just a guess.
I like the blue 1 worth the struggle getting in/out to me.
Once in and situated its miles of smiles from there .
Just go for it!
Marshal
Old Dec 30, 2012 | 04:34 PM
62corvette's Avatar
62corvette
"aero chairs"? Run Forrest, run!
Nobody has mentioned that all the chrome bumper cars came from the factory with a bag of shims and spacers to adjust the seat/s upward or change the angle. It's just possible someone used those rather than throwing them away.
Old Dec 30, 2012 | 05:40 PM
oldgto's Avatar
oldgto
My thoughts exactly. I`m wondering if this dealer came up with that, what other BS is he throwing at you?
Old Dec 30, 2012 | 06:47 PM
DJmaya's Avatar
DJmaya
Thanks for all the replies guys.
I am definitely not buying from this guy. The cars are overpriced anyway and I definitely do not trust this guy now after the whole "AeroChairs" BS.
I think modifying my chair is a good solution. Taking it of the tracks seems a little radical but i'll do it if using the shims and spacers does not work.
Glass tops would help but they are not really my style. if you guys were curious i am 6'4 and 205 pounds.
Old Dec 31, 2012 | 01:22 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Alan 71
...Same seats.... honest!...
Alan is correct. There are no differences in the seats of the two cars, other than the upholstery, unless a previous owner made non-stock changes to sit up a little higher.
Old Dec 31, 2012 | 06:06 PM
Big Block Dave's Avatar
Big Block Dave
Im going to take a wild guess and say that "aero" chairs are the pace car seats. Not that I have any experience with them, but they look a little "scooped out", kind of like gutting the bread material out of a bagel...is it possible that this could also give some extra clearance?
Outside of that, I would learn as much as you can about these cars by looking at those "coralled" at a dealer, then search privately
To C3 headroom variance
Old Feb 18, 2013 | 04:43 AM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Hey guys, David Howard here. You may or may not have noticed that DJMaya(Original Poster) bought my 1977 red modified coupe this past Saturday. He is quite tall and my seats had new foam and new covers installed on them so he definately sat tall in the saddle. The idea of removing the railing and mounting directly to the floor as well as removing the T-Top pad may be good ones for him and he mentioned those to me when he was here Saturday. Anyway, he bought a good car from me and drove it Saturday and Sunday back from Eastern, PA to Chicago, its new home. Watch for him to post soon and I hope he shares his experience with getting the seat the way he wants it on this car.
Thanks as always for helping out our fellow C-3 friends.
Best regards,
David Howard
Old Feb 18, 2013 | 05:12 AM
razman's Avatar
razman
[QUOTE=DJmaya;1582691743] "Hello gentlemen,
I found 2 for sale yesterday at a dealer near me so I decided to go test drive them."
no one even mentioned how rare these two cars that he is looking at actually are!! i mean, 62-63 T-tops???? (and aero seats) must be COPO cars..
Old Feb 19, 2013 | 12:59 PM
DJmaya's Avatar
DJmaya
As AllC34Me said, I did buy his 77 vette.
I drove it over 2 days for 12 hours with absolutely no mechanical problems. It really come to show how solid the car restoration is.
The headroom is actually a smaller issue than I had previously experienced on other C3s. My head is not actively touching the ceiling when on a "comfortable" driving position. After a few road bumps I learned to keep a closer eye on the road and lower my head when a bump/ bridge/dip/pot hole was unavoidable. The adjustable steering was great because even though I am 6'4 I could put the wheel at a comfortable angle as I switched positions every hour or so.
I have started looking into improving my headroom on the car. And I am starting with this list:
1) remove panel attached to the removable T-top
2) inclining seat into a more "bucket seat" angle
3) lowering/removing seat rails
4) reducing seat padding thickness and replacing with very high density padding
I have put them in an order of less to most invasive (and expensive) solutions.
