C4 wheels
Old Jan 3, 2013 | 11:59 AM
vish2000's Avatar
vish2000
Default C4 wheels
Hi, will a 94 saw blade set fit a 79?
Old Jan 3, 2013 | 01:21 PM
dburgjohn's Avatar
dburgjohn
the offset difference will require large adapters. not sure if I would want to run that. I have owned C4s and like the wheels, but think I would stick to direct bolt rims
Old Jan 4, 2013 | 10:04 AM
Rotonda's Avatar
Rotonda
You will need 2 1/2 inch to 3 inch adapters. The backspace on stock C3 wheels is 4 inches. Measure the backspace on your sawblades and order accordingly. A 'standard' set of sawblades has 8 1/2 inch fronts and 9 1/2 inch wide rears and this may alter the size of adapter you need (C3 stock is 8 inches). You will also need 12mm cone shaped nuts to fasten sawblades to adapters and 7/16 cone shaped nuts to secure adapters to car.
Old Jan 5, 2013 | 04:45 PM
dburgjohn's Avatar
dburgjohn
Default look like this
To C4 wheels
