Radiator Question
Old Jan 4, 2013 | 10:02 PM
johnnyw's Avatar
johnnyw
Default Radiator Question
My 71 convertible which is a 400 SB has a few leaks in the radiator and it looks to be a copper radiator. If I were to just replace it which is best for cooling Copper or Aluminum? I know it's not the original motor, the radiator has a couple of electric fans mounted in front of the radiator and I plan on leaving them on the car after replacing the radiator. It runs right at 200 deg. when hot and the fans keep it just below that when I cut them on. I would like to see it a little cooler than that. Also what is the best temp for a new thermostat? Thanks for any help.
Old Jan 4, 2013 | 10:09 PM
59LesPaul's Avatar
59LesPaul
One word...DeWitts, check them out. They make a great radiator and their customer servcie is second to none.
Old Jan 4, 2013 | 10:16 PM
johnnyw's Avatar
johnnyw
Thank you, I sure will.
gflash67's Avatar
gflash67
i agree i put a dewitts rad with the dual elect fans in my 71 454 vette which used to run a little hot in summer and it runs cool now even in high 90 degree weather
Old Jan 4, 2013 | 10:19 PM
Jeffery73's Avatar
Jeffery73
St. Jude Donor '08-'09-'10-'11-'12-'13
As far as I am concerned, Dewitts is the only answer. My car used to overheat with the stock radiator. I put in the Dewitts and I can leave it sit idling all day and it won't heat up. I drove in the 4th of July parade here in town last summer. Temp was near 100 that day and I had no problem.
http://www.dewitts.com/
Old Jan 4, 2013 | 11:15 PM
johnnyw's Avatar
johnnyw
Thanks for the good advice. I checked out Dewitt's site and I think I will go with the radiator and fans comb and get rid of the old clutch fan and shroud both.
Old Jan 4, 2013 | 11:17 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
Tom DeWitt makes the best Corvette radiator, bar none. And when you need to talk to customer service, you talk to Tom.
Old Jan 4, 2013 | 11:47 PM
3JsVette's Avatar
3JsVette
Smart decision!
To Radiator Question
