'76 Visors
Old Jan 5, 2013 | 05:12 PM
Cara1's Avatar
Cara1
Cruising
Default '76 Visors
The sun visors on my '76 seem to be stuck in the up position, they won't move. Does anyone know the reason for this and/or how I can fix it???
Old Jan 5, 2013 | 10:16 PM
sweeet76's Avatar
sweeet76
Default visors
I have the same problem with my 76. I just decided to sit up higher and let the top of the windshield block the sun or wear a cap lower. However it's probably an easy fix.
Old Jan 6, 2013 | 10:07 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Cara1
...The sun visors on my '76 seem to be stuck in the up position, they won't move. Does anyone know the reason for this and/or how I can fix it?...
Age and moisture. The visors mount on two chrome rods and can take a set when not moved.
If you cannot gently force them down, you may want to consider removing them and getting a little penetrating oil on each rod. Go easy on the oil. The AIM says the visors should take 7-15 lbs of effort to move.
Old Jan 7, 2013 | 11:11 AM
74Ken's Avatar
74Ken
And what happens when you force them down?
I was unloading my car from a trailer when I first bought it and was looking right into the sun. I instinktively yanked the drivers one down. Now it won't go back up without removing the unit and rotating the chrome bar all thew way around.
Is there another pience inside?
Old Jan 7, 2013 | 12:38 PM
jcloving's Avatar
jcloving
Just remove them via the screws and then you could pull out those chrome pins. They are probably just rusty or frozen in place. A clean up job should do it with some grease.
Mine were the same way.
Old Jan 7, 2013 | 12:55 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by 74Ken
...Is there another pience inside?...
Yah. I think Ernie at Willcox cut one apart for illustration purposes.
Old Jan 7, 2013 | 01:01 PM
74Ken's Avatar
74Ken
ok I see it, the rods are seizing in those metal sleeves.
that make sense now.
thanks
Ken
To '76 Visors
