Rally Wheels Interchangeable?
Old Jan 12, 2013 | 08:53 PM
bellaireroad's Avatar
bellaireroad
Default Rally Wheels Interchangeable?
Will 1967 to 1979 Camaro Rally Wheels interchange with 69-79 Corvette?
Old Jan 12, 2013 | 09:53 PM
Tom73's Avatar
Tom73
Bolt pattern should be the same but they are different widths. Not sure about the back spacing.
Old Jan 12, 2013 | 10:04 PM
Mooser's Avatar
Mooser
Weren't the early Camaro's 14" rims?
I don't think they will clear the calipers if they are 14's
Mooser
Old Jan 12, 2013 | 11:56 PM
gbvette62's Avatar
gbvette62
69-82 Corvettes all used 8" wide rally wheels. They were also 15" diameter. No other Chevrolet used 15x8 rally's.
The only Camaro that used 15" rallys, was the 67-69 Z28's, and they were 7" wide. The 70 and up Z28's used a 15" wheel also, but it similar to the 70-72 Chevelle SS wheel, and not a rally.
The Camaro rally has different back spacing than the Corvette wheel. Because of the backspacing difference, the parking brake cable bracket on the trailing arm, often causes interference issues with the 7" Camaro wheel.
Old Jan 13, 2013 | 12:24 AM
bellaireroad
Thanks…..going to pass on them
To Rally Wheels Interchangeable?
