69 C3 327 Stance
Old Jan 16, 2013 | 02:24 AM
MeanMachineStingray's Avatar
MeanMachineStingray
3rd Gear
Default 69 C3 327 Stance
Hello,
I am having my 69 Vette 327 Stingray completley restored and the colour will be changed from Monza Red to Cortez Silver.
However there is something wrong with the way the car sits, the front is very low and compared to my uncles 69 4 Barrel 3x2 427. Is there something wrong with the suspension or the tyres are extremely tall for this car.
The front should be higher and inline with how the rear suspension sits.
Old Jan 16, 2013 | 05:56 AM
vette_20's Avatar
vette_20
Originally Posted by MeanMachineStingray
Hello,
I love the stance i just lowered mine 1nch half and looks just like that
Old Jan 16, 2013 | 06:19 AM
Redwing01's Avatar
Redwing01
2015 C3 of Year Finalist
Personally i don't see anything wrong with the way it sits ...
Old Jan 16, 2013 | 08:05 AM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
What happened to the 350? No '69s came with a 327....
Old Jan 16, 2013 | 08:27 AM
sjohnson2615's Avatar
sjohnson2615
A lot of things can happen to an engine in 40+ years.
Are you just wanting to know the details of this particular 350?
Old Jan 16, 2013 | 08:33 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Your car looks fine to me based on the angle of the pic. Have you considered your uncle's car might be sitting too high?
Old Jan 16, 2013 | 09:22 AM
Faster Rat's Avatar
Faster Rat
I guess it shrunk. Hey...some things of mine have shrunk in 63 years.
Old Jan 16, 2013 | 05:00 PM
Alan 71's Avatar
Alan 71
Hi v_20,
The original ride heights for both the front and rear are found in the Assembly Instruction Manual.
The original tires were just about 27" tall. With those tires in place the distance, (ride height), from the ground to the center line of the fiberglass wheel opening was 27.91" for both the front and rear.
Checking that will give you some idea where you car is and should be.
Since your have you're restoring your car you may want to have the Assembly Manual and also the GM Chassis Service Manual on hand.
Good Luck!
Regards,
Alan
Old Jan 16, 2013 | 05:13 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
Originally Posted by Alan 71
Since your have your car restored you may want to have the Assembly Manual and Chassis Service Manual on hand.
Good Luck!
Regards,
Alan
Great advice from knowledgeable CF people.
FWIW, I don't see a thing wrong in the stance of your car. Looks great. Good luck.
Old Jan 16, 2013 | 05:22 PM
Mike Ward's Avatar
Mike Ward
That matches his uncles "69 4 Barrel 3x2 427"
The car is lower than stock in the front, probably aftermarket F41 springs.
Old Jan 16, 2013 | 08:27 PM
3JsVette's Avatar
3JsVette
Seems like the responses you're getting are consistent.
To 69 C3 327 Stance
