repair small crack?
Old Jan 21, 2013 | 09:51 PM
mwm1993's Avatar
mwm1993
Default repair small crack?
I'm looking at a 72 vette and the car has a couple blemishes around the front passenger headlight
Crack in fiberglass
and some small cracks in the paint. You can barely tell because of the glare
Is this something that can be repaired and painted without having to repaint the whole front end? Cost? Also is there a good chance that the car was hit at some point or could this be from improper preparation for paint? The car was repainted a while back. I couldn't find any signs of body work or the car being in an accident, although I could've looked harder. Other than those spots the car is pretty solid so it won't be a deal breaker
As always, thanks in advance
Mike
Old Jan 21, 2013 | 10:33 PM
jn76vette's Avatar
jn76vette
St. Jude Donor '08
I would think that a good body shop with experience doing corvette bodywork would be able to fix that easily. The front end of mine looked much worse after I got hit and they were able to make it look like new.
Old Jan 22, 2013 | 10:25 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
No harm done; either of these can be easily repaired. You can put both on the "Someday" list of things to do.
To repair small crack?
