Keyed Lock for the Spare.
78-82 Corvettes came with a Goodyear "Polyspare" P195/80D15 temporary spare. The tire was mounted on a 15x5, plain steel wheel. Some 78 Corvettes have been found with a spare wheel painted bright yellow, though most 78's and all 79-82's came with a black painted rim.
To the best of my knowledge, the P195/80D15 temporary spare, is no longer made. The wheels and tires do turn up, as there were over 200,000 Corvettes that came with them. As a spare, to use in a pinch, you'd probably be okay to use one of these 30+ year old tires. They were only designed to get you far enough to have your flat repaired anyway, and were rated for a maximum of 50MPH. P195/80R15 radial road tires are available, and would serve as a perfectly good spare tire, mounted on an original 78 15x5 spare wheel.
Regular Corvette 15x8 rally wheels and stock P225/70R15 tires, will fit in the 78 spare tire tub also. The optional P255/60R15 tires will fit too, but they cause the spare tire tub to hang rather low. It's fine to throw a flat 60 series tire in there to get somewhere to repair it, but not recommended to keep one in there on a regular basis. The tubs tend to get damaged in normal use as it is, and a 60 series tire, increases the likely hood of damaging the tub on a bump or driveway.
