Keyed Lock for the Spare.
And how many still have the orginal spare (dangerous though it may be) under your car? Who has removed it for looks. or replaced it for reliability with a newer tire?
I put a lock on my restored car. I don't think it was necessary. I'm positive a potential thief would have bigger things in mind than just stealing a spare tire from a classic Corvette. With that said, a C3 doesn't look complete without that spare tire carrier installed under the fuel tank.
I've never heard of anyone loosing a spare lock, while driving. Usually they disappear because someone took it off, and didn't bother to put it back (especially repair shops).
A bigger problem with the locks, is not being able to remove them. They either end up rusted up inside, or the owner doesn't have the key. It seems that a lot of these cars get sold, and the spare tire lock key, doesn't go with the car. I don't know if this is because people loose the glove box key (which also works the lock), change keys and forget to change the spare lock, or some other strange reason.
An awful lot of 68-82 Corvettes, still have their original spare. This is easy to understand with the 78-82's, since they have the temporary spare, which isn't likely to get removed and used. I think many of the 68-77 cars, still have the OEM spare, because so many of these cars got wider tires put on them over the years, leaving the spare as a mismatch. Also, the fact that it was under the car, made it a pain in the a$$ to remove, which may have dissuaded people from using it for tire rotations, etc.
I too still have the original lock and rubber boot.
I agree that the locks seem to have wanted to stay on rather than fall off as the years went by.
The spare is worn but is one of the original 5 tires that left St.Louis with this car.
Regards,
Alan
Is there a bolt hole built into it that I can carry an exposed spare tire?
When installed, the spare tire is not "exposed". The tire goes in a tub, that hangs under the rear of the car.
The spare tire carrier is made up of a lid, that's bolted to the frame, and the tub, which hangs from the frame by 3 bolts. At the front of the tub, there are 2 bolts, that are threaded into the differential crossmember, and then a third lock bolt is bolted to the center of the frame's rear crossmember.
To remove the spare, you loosen the lock bolt, move it asside, and the rear of the tub drops down to access the spare. The front of the tub hinges on the 2 front bolts.
All of the holes needed to mount the spare tire carrier, are in your frame already.
