Friction modifier, how much to add?
Old Feb 1, 2013 | 11:22 AM
AirborneSilva's Avatar
AirborneSilva
Default Friction modifier, how much to add?
How much friction modifier do you add to the diff? Thanks
Old Feb 1, 2013 | 11:39 AM
cv67's Avatar
cv67
St. Jude Donor '05
You mean posi additive? One of those tubes you get at the auto pts store will do.
Old Feb 1, 2013 | 11:42 AM
AirborneSilva
Yes, posi additive. This is the one I was looking to get
http://www.autozone.com/autozone/acc...ier=17352_0_0_
Old Feb 1, 2013 | 11:56 AM
BOSTONCAMARO's Avatar
BOSTONCAMARO
I always use two.....
Old Feb 1, 2013 | 12:30 PM
Brcmpbl's Avatar
Brcmpbl
Your manual will call for one bottle of posi additive, and I always go with the GM stuff. Any GM dealership is likely to have it. I use GM synthetic gear oil in the diff myself, 75w-90.
Old Feb 1, 2013 | 01:33 PM
AirborneSilva
Thank you
Old Feb 1, 2013 | 01:54 PM
ironwills76corvette's Avatar
ironwills76corvette
Is it this?
http://www.amazon.com/GM-Performance.../dp/B0028CMPIS
Do you know what was put for fluid when you had it rebuilt?
Old Feb 1, 2013 | 02:14 PM
AirborneSilva
No I don't know what they put in it, I'm sure it was the 75 90 judging by the consistency of it (the stuff that has leaked onto the garage floor that is)... As for the additive I'm going to get the stuff from Autozone unless I can get to a Chevy dealer on the way home this afternoon.
Old Feb 2, 2013 | 10:11 AM
71scgc's Avatar
71scgc
Use the GM additive.
On my recently rebuilt diff, the rebuilder spec'd Lucas 85-140 and one bottle of GM posi additive at the 500 mile point. Lucas diff lube has no additives included. Some do. If the lube you use says it contains the limited-slip additive, I would still add a bottle of the GM additive.
Some say 1 bottle. Others say two. I think either is okay.
Carter
Old Feb 2, 2013 | 08:15 PM
AirborneSilva
thanks, they lube I put in did say limited slip on it but I still put in a bottle of additive
Old Feb 4, 2013 | 07:27 PM
FastEddy's Avatar
FastEddy
The oil may say "limited slip" but that does NOT mean it has the additive in it. Personally, in 30 years, I've never seen gear oil with the additive already in it. It usually says it's for limited slip, but it still doesn't have the additive in it.... they are just claiming it's appropriate for limited slip diffs.
Old Feb 4, 2013 | 07:48 PM
AirborneSilva
Then I feel good about having putting the additive in it
To Friction modifier, how much to add?
