Rear end decoding help
Old Feb 2, 2013 | 02:12 PM
40ZR1's Avatar
40ZR1
Default Rear end decoding help
Is there a site that shows how to decode the numbers for engine, trans and rear end?
I have a rear end that has the following numbers:
OK159 V(?)8E1 Can anyone help?
Also, I can pull the stub axles out about 1/4", is that normal?
If the ceri-clips are off the stub axle, will the axles come out?
CJ
Old Feb 2, 2013 | 04:09 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Ok 3.08:1 1978
The play sounds excessive and it is very common when the rear end yokes get worn.
The yokes will also flare on the ends if worn badly and prevent you from pulling them out. Sometimes we have to tap them out with a small hammer.
Old Feb 2, 2013 | 04:32 PM
40ZR1's Avatar
40ZR1
Thanks, Wilcox. Is it a positraction?
CJ
Old Feb 2, 2013 | 05:36 PM
Alan 71's Avatar
Alan 71
Hi cj,
Yes, it's posi-traction.
Regards,
Alan
To Rear end decoding help
