Interior Swap
Old Feb 3, 2013 | 09:27 PM
MyRCar's Avatar
MyRCar
4th Gear
Default Interior Swap
I just purchased a 1980 Corvette and I want to redo the interior. I would like to change the dash from it's original style to an earlier 68-77 style dash and console. Has anyone done this or know if it can be done?
Old Feb 3, 2013 | 09:32 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Why man?
Old Feb 3, 2013 | 09:41 PM
MyRCar's Avatar
MyRCar
4th Gear
I have never really cared much for the newer style dash over the older.
Old Feb 3, 2013 | 09:58 PM
PaPaPork's Avatar
PaPaPork
I have a 79 and my plastic, square "tunnel" covering the speedometer and tachometer is cracked, I was wondering if its a simple swap to change to the dual round tunnel from the earlier cars?
PS. did not mean to hijack but no point of starting a second thread on the same topic
Old Feb 3, 2013 | 10:06 PM
MyRCar's Avatar
MyRCar
4th Gear
I'm pretty sure it will require a complete replacement of the dash and console. I am just not sure if the older style will fit without any major fabrications.
P.S. No worries jumping in, it can only help bring in the information.
Old Feb 3, 2013 | 10:19 PM
gbvette62's Avatar
gbvette62
I'm sure it can be done, as I know that others have gone the other way, putting a later dash, in a 68-77 car. The basic cowl and windshield frame, are the same on all 68-82 Corvettes.
You'd probably want to stick with a 75-77 dash, as they used an electric tach and oil pressure gauge, just like the 80 does.
I'm not exactly sure, what you mean by "tunnel", but the 79 dash is completely different than the 68-77 dash, with the round speedo and tach.
The 68-77 dash is made up of three pieces. There's the left front piece with the speedo/tach, the right front piece with the map pocket and the dash top. The 79 dash is all one piece.
So it your inquiring if you can use the round speedo and tach, in your 79, then yes you can, but it is not a "simple swap to change". To do it, you would need to use a complete 3 piece dash from an earlier car, just like MyRCar is contemplating doing.
Old Feb 4, 2013 | 05:25 AM
PaPaPork's Avatar
PaPaPork
http://i3.photobucket.com/albums/y51...c/DSC07893.jpg
on this pic of a 79 interior the tach and speedo are round but there is a rectangular bezel with a fake chrome edge around them, I was wondering if an earlier round bezel would fit there. I do not know how the earlier cars are build so please forgive me if this is a stupid question and there is no way it will happen.
(sorry for using sbodys photo - just found it on google image search)
Old Feb 4, 2013 | 06:58 AM
Rotonda's Avatar
Rotonda
The 77 interior was a hybred of earlier and later designs. It incorporated the later tunnel and center stack with the round inset speedo & tach and map pocket of earlier models. It also introduced revised windshield trim that was carried forward onto later models.
If you're going to retrofit yours, I suggest that you use 77 pieces as your basis. (FYI, the 77 center stack bezel hes minor differences on how it meete surrounding trim. You will not be able to use your original.)
Old Feb 4, 2013 | 08:15 AM
gbvette62's Avatar
gbvette62
No, as I said in my previous post, the 79 dash is all one piece, were as the 68-77 dashes, are made up of 3 separate pieces.
Unlike the 78-82 speedo and tach, which are mounted in a removable housing, the speedo and tach on earlier cars, are mounted directly into the left side of the dash panel. This is the whole left side dash, it goes from the door to the center gauge bezel, and from the dash top, down to the steering column.
If you want to add earlier gauges to your car, you have to replace the entire dash; along with the gauges, glove box, center bezel and a-pillar moldings.
Sorry, but you just can't just swap in the earlier speedo/tach.
Old Feb 4, 2013 | 08:42 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Trade the 80 and purchase a 68-77. This swap involves more than just a dash. Retrofitting the main dash wiring harness is a consideration.
Old Feb 4, 2013 | 08:56 AM
mark6669's Avatar
mark6669
Can be done, finding the three dash panels and a center console used and in good condition won't be easy and the new parts are over $1000 plus gauges, would require modifying main harness but it can be done, not for the faint of heart.
Mark
Old Feb 4, 2013 | 08:58 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
This would be a project for sure and the 77 would probably be the easiest conversion. The speedo tach connector would have to be modified but the center gauge cluster would plug right in. You could keep your old gauges for the center cluster and just replace the plastic bezel (77 has flaps on it that the 78-82 doesn't have).
Old Feb 4, 2013 | 11:45 AM
7T1vette's Avatar
7T1vette
I think it might be simpler to buy an earlier C3 and change the body...
Old Feb 4, 2013 | 12:04 PM
PaPaPork's Avatar
PaPaPork
Thank you
To Interior Swap
