Does anyone know which is power and which is ground on a 76 ammeter? It has a copper terminal and a silver colored terminal. The tabs for the plug can be assembled both ways.
Yes. But, which side you put the leads on determines which is + current flow and which is - .
As mentioned, the ammeter is just tapped-onto the main power feed line in the wiring harness. It is not actually inserted into the line, but the feed wires are attached to that line in two places a set distance apart. The small resistance in that section of harness wire acts as a 'shunt' resistor; and the voltage drop over that section of line [which is proportional to the amount of current flowing] is what the meter actually reads. The dial face is only 'calibrated' so that you can read AMPS.
You want to put the two wires on the meter so that it will read + direction when charging and - direction when discharging. It's much easier to check for discharge amps by just turning on the lights. If you try it and it reads backwards, just switch the two wires.
attemting to get my amp meter circute to work, orginal gauge was not working so replaced with no luck , then did a check to new gauge by tapping in a 1.5 volt battery and gauage is good to go, in your experice i am trying to find the location of the attached photo were the fusable link is located and the battery tie in point. appricate the heads up.
Thanks Rob
The fuse link that ptotects the gauge is the small (20 gauge) orange wire on the horn relay. Before you have to go riping into the wireing, check for power on both the wires for the gauge, with the gauge disconnected you should get battery voltage on BOTH wires.
