Is this acceptable upholstry work?
Old Feb 20, 2013 | 01:22 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Roco71
...Those suckers can get hot enough to peel paint....
That is exactly what I have used mine for: paint removal.
Old Feb 20, 2013 | 01:30 PM
Scratch's Avatar
Scratch
Veteran: Marine Corps
St. Jude Donor '03-'04-'05-'09
I know some upholsterer's inject steam inside the foam, it will expand and smooth out the fabric.
Old Feb 21, 2013 | 04:26 PM
Priya's Avatar
Priya
They possibly do and they're pros. I'm an amateur and want nothing to do with that much heat close to my upholstery.
Use a hair dryer and you'll have no concerns about melting/burning your upholstery.
Old Feb 22, 2013 | 07:29 PM
fly1977's Avatar
fly1977
I have done a fair amount of corvette seats, these are not perfect but not bad either. Hard to get wrinkles out. The best way is with a upholster steamer not just heat . afer a little use most of them will go away.
Old Feb 22, 2013 | 08:42 PM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
You don't need to be a pro to use the heat gun just keep it 8 or 12 inches from the seat and use your hand on the seat cover to smooth the wrinkles and monitor the heat. If your still concerned the hair dryer or hot sunny day w/ careful parking will help !
Old Feb 22, 2013 | 09:26 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The covers look good.. but the wrinkles should not be there.
Steaming the foam is a temporary fix and actually swells the foam... I call this an old used car trick!
Steaming leather covers is a NO NO.. never let a shop steam the leather covers.
If the covers are vinyl heating them with a heat gun (if you are not experienced, use a blow drier) will shrink the wrinkles right out. You just have to keep the heat moving and you'll be fine.
The covers look like Vinyl.. so give it a go.. or wait for a hot day.. that will remove most of them.
