Installing New Shifter Question
Old Feb 20, 2013 | 11:42 AM
Jim Myers's Avatar
Jim Myers
Default Installing New Shifter Question
Is it necessary to remove the transmission to install a new 4 speed shifter in a 69?
Old Feb 20, 2013 | 11:51 AM
toolman0114's Avatar
toolman0114
Wasn't on my 74, just gotta work from inside the car as well as underneath it.
Old Feb 20, 2013 | 11:52 AM
F22's Avatar
F22
No, because I don't think you can install the shifter on the transmission AND put it back in the trans tunnel, without some serious problems. This is because the crossmember is not removable on the C3's.
You'll have to set it up from above and below, removing the shifter boot and getting underneath to set up the rods and linkages correctly.
Old Feb 20, 2013 | 12:22 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
C3 4 speed shifters do not bolt to the tranny; they mount on a bracket beside the tranny. AIM shows it and will help you before you crawl under there.
Old Feb 20, 2013 | 12:39 PM
F22's Avatar
F22
True dat'! I wonder if you could bolt up the whole shebang (shifter, rods, etc) TO the bracket before you mount it to the crossmember? Or would you mount the bracket first and follow up with assembling the shifter, rods, etc?
I'm about to do this really soon, so any answers would be appreciated!
Old Feb 20, 2013 | 01:09 PM
mark6669's Avatar
mark6669
Haven't done one in a while. I think I put the bracket in place unbolted, bolt the shifter with rods attached to it then bolt bracket to cross member, makes it easier to get to all the bolts its very tight working up there. then install rods to trans and adjust.
Mark
Old Feb 20, 2013 | 02:47 PM
F22's Avatar
F22
Mark
The clearance was what had me wondering! Thanks!
To Installing New Shifter Question
