Spare Tire Compartment Question
been in the compartment, but it was a Goodyear "Wide Tread" F70 X 15. When I sold the car, I was running F60 X 15's and the spare time was what every came with the car new.
At the moment, I'm running BF Goodrich 245/60/15's and I want to get a similar tire for the spare...BUT because of the size of the compartment, you can only put so big of a tire in there. The big problem is width. Right now..the old F70 sits about an inch higher
then my 245/60...so no problem on diameter. I thought about going
to maybe a 215, 205 or maybe a 195/60 for the spare, but I'm still not sure if that will fit in the carrier. Another possible problem..if I do get one of those tires for a spare...and it fits inside the compartment,
what happens if I get a flat, put the spare on...and the 245's won't
fit in the compartment? Looks like the passenger would have to ride with a big tire in their lap, until I could stop and get it fixed.
On the C4's which have a similar tire compartment...they had a double
hinged on the front of the carrier...for when you had to change your ZR1 tires. Apparently it would drop down in a lower slot, in order to fit the larger tire in there.
I'm also thinking..if diameter is no problem...only width...perhaps I could use a longer bolt on the rear of the carrier..and not raise the bottom of the carrier as far up in the compartment. It could hang down several inches in the back without being noticeable.
Anyone had any experience with this problem...or suggestions?
Jeff
http://forums.corvetteforum.com/c3-g...-question.html
