1978 engine and trans question.
1. What type of trans did the come with? 350 right? Also would a trans, drive shaft and trans yoke from any other year c3 work (1976-1982)?
2. the engine that these came with was nothing special correct? so any chevy 350 from this era will work?
3. Im assuming the pace cars and all other 78s were just different by the paint, interior and VIN correct?
Thanks!
In 78, the hood was designed to permit hot air to exhaust through the rear while cool air was directed through the radiator. The hood was slighly higher toward the rear and therefore should fit most refits. But in the later years, leading up to 78, cool air was brought in through plenums that sat on the radiator and fed the air cleaner. This is in contrast to the single chrome air cleaner from earlier years that sat atop the carb. Engineers learned by late years that the radiator directed cool air increased horsepower
Than there are the emission control devices that eventually took up space such as the smog pump, diverter valves, pipes that plugged into the manifolds, EFE, EGR, etc.
