I finally got around to installing my interior door panels from Corvette America. It involved a little trial and error due to the vague instructions, but I figured it out.
The problem that I'm running into is a decent gap between the panel and the door towards the bottom. The retaining clips don't really hold the panel flush to the door.
Anybody have any ideas (that doesn't involve putting a screw through the door panel) to reduce this gap?
I had the same problem with a 77. I got big wood clamps and clamped it to the door than used a heat gun to heat it up and it got the shape it needed. I got the panels from Corvette America. Just be careful with the heat gun.
I think the 'accepted' approach is to warm the panel (using sunlight is more gradual and has less risk of damage) with some weighting on it so that it will straighten before installing. With factory panels (fiber core), the fiber core needs to be dampened first. With a styrene core, turning the panel upside down and supporting it underneath at top and bottom, some time in bright sun with some weight placed in the center of the panel should do it.
Good tip....because I'll installing new panels soon !
I searched the forum when I installed mine, and came across a very brave individual who scored across the back of theirs with a blade to give it a bit of movement.
With the door panel off, I drilled out the rivets on all of the plastic velcro pieces. I then drilled small slits in the panel, and small holes in the door, so that modern panel retainers could be used. I placed the retainers in the center of where each of the velcro retainers were.
This worked very well, and if I ever want to go back to stock retainers, then I can simply rivet the original plastic velcro retainers back into the car, and they will cover the holes.
Interesting...... VERY interesting!
(I just may try this!)
