Which is it?
Old Mar 6, 2013 | 08:25 AM
Cattiva73's Avatar
Cattiva73
Default Which is it?
Hallo...Corvette newbie here... again
My '73 has a chevy 402 engine with this carburetor...it runs pretty good and I know it's a Holly but I have no idea which model or size is it. ??..maybe a 650?
..and is it a good fit for that engine ??
....If you could tell me your opinion on Holly carbs it would be great
Old Mar 6, 2013 | 12:13 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
http://www.ebay.com/itm/HOLLEY-CARBU...-/320956520313
Holley makes good carburetors.
Old Mar 6, 2013 | 12:29 PM
CQRT's Avatar
CQRT
Holley 650 cfm street carb - -
http://www.holley.com/0-80555C.asp
Good stuff- should be fine your that engine . .
Old Mar 6, 2013 | 12:47 PM
gbvette62's Avatar
gbvette62
The 80555 is a Holley direct replacement carb, for the factory Q-Jet. It features a spread bore bolt pattern, just like the Q-Jet, so that it will bolt right onto the stock intake. Holley still makes them, and they list for around $400.
Personally, I prefer the Q-Jet, for street duty. The Holley is easy to work on, and it's easy to change things, like the jets. We run them on all of the vintage racers, I work on. I've just always found the Q-Jet to be a nice, simple and reliable carb.
Old Mar 6, 2013 | 02:39 PM
Cattiva73's Avatar
Cattiva73
Thank you guys...Very helpful as usual.
Old Mar 6, 2013 | 02:40 PM
qwank's Avatar
qwank
I had one of those spread bore Holleys on my od K5 Blazer. it was a great carb
To Which is it?
