Car wpnt start ? ? Ignition ?
Old Mar 10, 2013 | 08:40 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
Default Car wpnt start ? ? Ignition ?
Ok so I havent started the car in a few weeks. THe car is on a charger.. And I went to start it tonight and it wouldnt start.. I pulled a plug and I dont see any spark.. ? ? I may have left the key in the on postion the last time I started the car.. What would you think it would be thats burnt out ? ?
I have never had an issue in the past... Thoughts ? ?
Old Mar 10, 2013 | 09:02 PM
imariver's Avatar
imariver
If you left the key in the "run" position that long, you may have burned the coil out. (?)
'75's Avatar
'75
Didn't say what year it is, but if it has points, they could be burnt due to the key being left on.
Old Mar 10, 2013 | 09:28 PM
Chinaski's Avatar
Chinaski
St. Jude Donor '14
Did you check the battery cables?
Old Mar 10, 2013 | 09:30 PM
ptroxx's Avatar
ptroxx
Its turning over no problem.. ?
ptroxx's Avatar
ptroxx
THis is what I was thinking... what about the module ? ?
Old Mar 10, 2013 | 09:37 PM
ptroxx's Avatar
ptroxx
Also, Wonder if the coil will be different from my 77 coil.. I have a ZZ4 crate motor....
Old Mar 10, 2013 | 09:42 PM
'75's Avatar
'75
If it's HEI, remove the tach wire from the cap and put your 12 volt test light on the terminal and crank the engine. If the test light flashes, the module is good.
Old Mar 10, 2013 | 09:55 PM
nfirst26's Avatar
nfirst26
2nd Gear
I had the same issue. Out of nowhere the car wouldn't turnover, it sounds like the coil in the distributor.
Old Mar 10, 2013 | 11:21 PM
ptroxx's Avatar
ptroxx
All fixed... thanks all... bad coil...
To Car wpnt start ? ? Ignition ?
