Dying my interrior. More help needed
I'm in the final stages of buying a 74 stingray that's black with a silver interrior. The interrior is flawless in every way. It has the deluxe doors with the carpeted pieces on the bottom. Everything is in excellent shape.
The thing is, I want to change the interior to black save for the seats which I want to be deep red.
1. What parts can and can't be dyed? I've never dyed anything and not sure what can be dyed.
2. I've heard of a canister type dying device so I don't have to invest in a full paint shop! What's the name of it and where do I aquire it?
3. Is there a thread here that details the dying process and drying times?
4. I plan to just replace the seats so they look perfect.
Any help is much appreciated. Ill post more here when my project begins.
1. Clean the hell out the parts with a non amonia, non armor all cleaner.... And when you think you've removed all dirt, oils, greases, etc... clean it again.
2. Use an adhesive promoter (3M's worked great)
3. Follow instructions on how much time between promoter coats and dye (I think its 10 minutes)
4. Spray several thin, light coats of your chosen vinyl or plastic dye, again pay attention to the directed time between coats. Many thin coats worked best for me. (Again 3M or VHT from Summitt Racing work better than Duplicolor, though I have no experience with the VHT)
5. Allow to dry in a hot dry place for as long as you can let it go, while working on whatever else. Minimum of a few days I'd say.
6. Area's I wouldn't dye again... Seats (they show some wear, as other parts do not show any after 1 year) and the arm rests of the doors. If you do the doors, perhaps a clear coat over the dye would help though I haven't tried this yet.
Good luck... (Personally I think I'd leave it the same color, even redye the same color over it.)
Good choice on the seats, by the way. That's one of my next purchases.
One other thing to consider...changing the interior, if the car is otherwise original and in good overall shape, is very likely to lower the market value of your car in a sale later on.
SEM Landau Black is what I (and almost everyone else) used....
It's in a regular old spray can "rattle can".
Buy the SEM "Prep" stuff to. Clean it REAL good then use the "Prep", then spray on the color... Light coats. Dry at least 30 minutes between coats. The stuff is magic!
These were tan.....what do you think ?
Original seats.....trashed...had to go.
Fiero seats in conditioned I bought them
Re-Covered
In Car
You can do it !
You can dye any interior part you want. Colorcoat is good for all plastics, leather and it even works on metal...although it is not as durable on metal as other paints that are made for it.
Clean the parts really well with detergent; years of using Armor-All or other 'protectants' puts a heavy scum of that stuff on the parts. Then rinse all detergent from the surface and allow to completely dry. Some folks say that a primer needs to be used. Well, that may be true with the cr@p the aftermarket places sell as "Vinyl Dye"
, but it's not necessary with the 'good stuff' [SEM Colorcoat liquid dye]. There are spray cans of SEM, but IMO they don't have the same sheen as the liquid stuff and don't look like factory-new vinyl. I know how SEM Colorcoat liquid dye looks and lasts on used parts--and THAT is what you want.You can replace the seatcovers "so that they look perfect" if you want. If yours are damaged or worn, that is probably the best idea. But, "new" aftermarket covers may not look exactly like stock covers. The ComfortWeave cloth in early C3 vinyl seat were formed differently than the replicated stuff from the aftermarket folks. So, make sure of what you want to do before you do it.
