Never say never, but usually Yes, with the same gang stamp tool by the same assembly line worker.
Thanks Mike, for your reply - that was the answer I was looking for. Just noticed that the s/n on the engine stamp pad and on my TH400 looked identical (same font). One of the digits in the s/n on both the engine & tranny have the top part of the "4" (slightly faint) being the same. Hence the question - were they stamped on the same day?. With the consistency of both s/n stampings - looks like they were done @ the same time. Appreciate your insight.... BK3
Hi bk,
Your point about the similarities in the engine and transmission stamping is a good reason why the transmission should be considered as part of the 'matching numbers' determination in my mind.
The car really does tell it's own story if you let it.
Regards,
Alan
