Nose support
Old Mar 16, 2013 | 03:23 PM
qwank's Avatar
qwank
Default Nose support
I know where all the body mounts are located, but what supports the nose on an '81? I need to adjust mine up on the right side a little so it's even with the left side. I'm thinking a mount may be sagging a little on that side.
Old Mar 16, 2013 | 04:06 PM
diehrd's Avatar
diehrd
Thats not a sag . Nope , what that is , is a sigh .. your car is sad it aint got no rear window louvers..
Old Mar 16, 2013 | 05:27 PM
qwank's Avatar
qwank
Lol!
Old Mar 16, 2013 | 08:08 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
2 brackets on the lower core support along with the braces from the front frame stubs,
Neal
Old Mar 17, 2013 | 12:21 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The hood surround header bar also has brackets on the front of each fender skirt. UPC 11A Sheet 1 in the AIM.
Old Mar 17, 2013 | 01:12 PM
qwank's Avatar
qwank
Thanks guys I'll check the AIM for the picture. Is there any adjustment in these brackets?
Old Mar 17, 2013 | 01:21 PM
qwank's Avatar
qwank
so is the radiator core support mounts Letter G bolted directly to the brace, letter F with out a rubber mount on UPC11 sheet 1?
Old Mar 17, 2013 | 03:10 PM
gcusmano74's Avatar
gcusmano74
A little bit. The mounting holes on the angle brackets are oversize, and the washers as well, so that you can move them around some.
After I changed out my body mounts, I was wondering. The factory mounts the body to the frame with rubber in eight places. Why solid mount the two radiator support brackets? Won't that be an avenue for Noise, Vibration and Harshness?
So I got some front shock absorber bushings and longer bolts, to "shock mount" the radiator support, using the stock brackets. I got bolts whose unthreaded shank was just long enough to slightly compress the rubber bushings when fully tightened. One bushing was placed on top, between the frame and bracket, and one under the bracket.
According to the completely unscientific seat of my pants, it helped cut down slightly on the NVH. I am calling it a sucessful experiment.
Old Mar 17, 2013 | 03:54 PM
qwank's Avatar
qwank
That's a good idea. adding the rubber mounts and a couple of shims may raise the nose enough to accomplish what I'm trying to do. I only need to go up about 3/8" on the right side
Old Mar 17, 2013 | 04:29 PM
diehrd's Avatar
diehrd
So how long has you had this lean to the right ? I have herd if you put a TV out with the car and run Bill Mayer from HBO for 24 hours the car may fix it self with the left leaning broadcast directed at the car. BUT If the lean is ultra right your gonna have to get Michael Moore to help ya.
Old Mar 18, 2013 | 10:36 PM
qwank's Avatar
qwank
Everything in my household leans to the right. LOL
So today I looked at the car to see what I could do to raise the right side up some. I noticed that these 4 bolts for the bumper support weren't as tight as they should be. I loosened them a little more, then with a block of wood on a jack I jacked up the bumper support and tightened the bolts. after a quick drive around the block I measured from the floor to the bottom of the fenders and it's exactly 26 7/8" on both sides. success!!
To Nose support
