C3 exhaust query...
Old Mar 17, 2013 | 03:44 AM
1968WhiteC3's Avatar
1968WhiteC3
5th Gear
Default C3 exhaust query...
Hi all,
First up, sorry if I'm posting this in the wrong area but I'm new to forums in general.
I am the proud owner of a '68 vette (a dream of mine since i was a child!) and am gradually tinkering with it. The only aspect I can't do is the exhaust, I'm in Australia, and had this beauty imported down here about 8 months ago. I've taken it to my usual exhaust place to get a set of hooker super comps fitted, and once they were I enquired, about getting the rest of the exhaust done, and he informed me that due to the centre crossmember where the exhausts go through (the cutout) I can only fit a max of 2-1/4in pipes through it, is that correct? I've had it up on stands at my place and it seems like I can fit larger through it.
My dilemma is I can't find anyone other then this place willing to touch it! I have no idea why as its not really any different to our old school holdens down here! (Other then being LHD)
So any suggestions? Have you had similar problems? How did you overcome them!?
I'm looking to go 2-1/2 minimum but preferably 3in!
Cheers;
Peter.
Old Mar 17, 2013 | 05:13 AM
CraigH's Avatar
CraigH
Originally Posted by 1968WhiteC3
Hi all,
Cheers;
Peter.
Hi Peter
I am in oz I can assure you 2.5" will fit through my 71 crossmember.
Covered here in more detail >. http://forums.corvetteforum.com/c3-g...ourney-22.html
2.5" mandrel bent with lukey mufflers at the rear.
Old Mar 17, 2013 | 05:44 AM
1968WhiteC3
5th Gear
Thanks mate! I was sure a 2-1/2 would fit! I'm assuming there was no modifications needed? I might have to give them a call back and/or show him your pictures.
Old Mar 17, 2013 | 05:51 AM
CraigH's Avatar
CraigH
No crossmember mods needed, fitted with some clearance still.
Old Mar 17, 2013 | 11:04 AM
7T1vette's Avatar
7T1vette
The factory installed 2-1/2" pipes through those crossmember openings with no problem. You should obtain a copy of the 1968 Assembly Instruction Manual (A.I.M.). It will show all that detail and what parts are associated with that installation.
Old Mar 17, 2013 | 11:13 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You can order pre-bent factory style exhaust systems from the aftermarket providers. Unless you have made extensive engine mods, 3" is too big for your car and will serve no benefit.
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Lots of us are running 3" pipes through there. Not a problem.
Old Mar 17, 2013 | 11:55 AM
mikem350's Avatar
mikem350
You could order the factory hangers and parts for a BB car or make sure they say 2.5 inch. I got mine from Corvette Central...check out their exhaust kits/parts too, give you an idea of what you need..maybe show the pics to your exhaust guy.
Old Mar 17, 2013 | 03:22 PM
gcusmano74's Avatar
gcusmano74
Yes, a 3" pipe will fit through the crossmember. Just barely. The only problem is getting it precisely dead nuts in the middle of the holes. Not much "fudge factor" there. Very little room for error.
Two and a half inch tubes are much easier to fit.
Old Mar 17, 2013 | 11:10 PM
1968WhiteC3
5th Gear
Thanks to everyone for their input! I'm going to the exhaust shop on Wednesday to have another chat with him. I'm not doing any major engine mods, just what's already done (and that was only dress up the bay) so 2-1/2 will do if he can't/won't do the 3in.
Cheers
Old Mar 18, 2013 | 10:45 AM
69427's Avatar
69427
I had no problem at all fitting my 3" pipes. I just cut a couple pieces of quarter inch wall PVC pipe to use as shims to center the exhaust in the crossmember while I was fitting and welding it.
Yes, 2 1/2 inch pipes are easier to install, but that's not the preferred option for some of us who are making some decent power numbers.
Old Mar 18, 2013 | 03:08 PM
C3 Stroker's Avatar
C3 Stroker
Cheers
Yes, 3" will fit, just be precise, and remember there is slightly less ground clearance than with 2½" pipes. You can run a 3" system that looks stock with Magnaflow equipment.....
Old Mar 19, 2013 | 09:44 AM
1968WhiteC3
5th Gear
Thanks for the photos mate!
Ground clearance isn't a problem for me, and to be honest I like the look of the larger exhaust pipes sitting low and visible, as is the case with your car. Looks awesome!
To C3 exhaust query...
