rear bumper bracket question
Old Mar 20, 2013 | 10:07 PM
73silververt's Avatar
73silververt
Default rear bumper bracket question
my bumper brackets were attached to the frame with 2 bolts each, i made sure to keep each bracket with the hardware togeather as they came off car. so now that its going back togeather its another puzzle, the left bracket was 2 bolts, 2 serated washers, and 2 nuts, right side 2 bolts, 4 serated washers (one between bolt and frame, the other between the nut and frame) and 2 nuts. the aim is not clear to me, lot ging on in the illustration, anybody know how it os supposed to be
Old Mar 20, 2013 | 11:39 PM
Postal123's Avatar
Postal123
My car only had the two large washers on each bolt head. From the looks of your pics (I cant see the bumper attachment end, but it looks like they are correctly oriented left/right) it looks like there were two washers used as shims on the 'left bracket' (the one on the right in the pic) in between the bracket and frame. I assume this was done to shim it up...? Try mounting without the washers and see how it aligns with the hole in the rear panel.
If you've changed out body mounts, you may need to shim and adjust all over again.
I can't remember, because I'm now on an aftermarket frame, but if you've got space on the inboard side of the frame I would use a large washer for each nut as well; to prevent gouging. This area was a challenge on the SRIII frame because the tube takes up too much space for a washer under each nut.
Also, recommend you thread a bumper attachment bolt loosely into the end, then guide the bracket up install the bolts. Then keep an eye on things as you tighten 'em up.
Hope this helps,
Rob
Old Mar 21, 2013 | 09:00 AM
Alan 71's Avatar
Alan 71
Hi 73s,
I looked at my 71 and there are 2 of the serrated washers on each bolt.
It would not surprise me one bit if your car got out of St.Louis missing 2 washers.
Regards,
Alan
VERY nice looking fasteners!
Old Mar 21, 2013 | 09:20 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
In the 72 AIM, same rear bumper page as your post, shows a serrated washer under the bolt head, bolt passing through the bracket and frame, and a second serrated washer and nut for attachment.
Old Mar 21, 2013 | 10:48 PM
73silververt
looked closer and could see witness marks from serated washers on both sides, nut and bolt, i think a couple must have got lost on a previous to me repair. thanks
Old Mar 21, 2013 | 11:07 PM
rogman16's Avatar
rogman16
Awesome... For the rest of us, please take some pictures during install and after completion... I'm about 6 months behind you and for some reason, and I can't find the pictures of me removing the brackets that you are dealing with... Good pictures on the 2 pairs on the inner rear bumpers, but none on the outside ;-( I have the AIM, but you know as well as I do, actual pictures are much better...
Thanks much
Rogman
Old Mar 21, 2013 | 11:15 PM
73silververt
i'll take some photos and post, sending it to my body guy tomorow to get right rear fender, tail lamp panel and passenger door pillar replaced, previous crash damage that wasn't repaired properly (butcher job)
Old Mar 21, 2013 | 11:22 PM
rogman16's Avatar
rogman16
Shak!! Thanks much... Looking forward to seeing the progress on your car... Can't ever take too many pictures as I've found out!!!
Rogman
To rear bumper bracket question
