I'm over thinking this simple ?
Old Mar 25, 2013 | 08:53 AM
lance m p's Avatar
lance m p
Default I'm over thinking this simple ?
PCV valve on the 82 its on the drivers side valve cover, ok I know what its for to vent the crankcase and purge the vapors to the purge canister. I have 15 different opinions on this. Before pcv valves all eniges had JUST a breather-no pcv. Now some one says you have to run a pcv because of ring seal, makes sense ALMOST because on the Buick Turbo cars the pcv valve is not connected to the valve covers instead its in the intake manifold so how in the hell does that have anything to do w/ring seal?-nothing. Point being on my 82 I was going to run 2 breathers one in each valve cover and run the intake vaccum line straight to the purge canister and be done. Any educated opinion on this ? thanks Lance
Old Mar 25, 2013 | 09:05 AM
540 vette's Avatar
540 vette
Your going to have a mess on your valve covers. Why do you want to run 2 breathers and no PVC.
http://en.wikipedia.org/wiki/Crankcase_ventilation_system
Old Mar 25, 2013 | 09:13 AM
bobbarry's Avatar
bobbarry
Even the old crankcase-vents had a "draft-tube", which created some negative pressure in the crankcase (at least while the car was moving). Short of going with a full vacuum-pump and separator to evacuate the crankcase and control the oil, a PCV system is the most practical way to prevent the buildup of pressure in the crankcase from the inevitable blowby, and to contain the effects of oil residue in the vent.
I mean, you can do the two vents, but then you'll discover first-hand why people don't usually do that on a street car.
Old Mar 25, 2013 | 09:15 AM
gerry72's Avatar
gerry72
Pre-PCV was a road draft tube. Breathers were primarily a place to dump in oil and provide some ventilation for the flow through of the draft tube. Interesting to note that PCV was not originally an emission control device. PCV started as an option from the factory and sold to the consumer as a path to a cleaner engine and less messy driveway. This is why you see some cars of the same year -both sold in CA- with and without PCV.
Running breathers alone without a draft tube is only half of the most basic system to vent crankcase pressure.
I can't see how a complete and functional PCV would aid ring seal. I believe they may be mixing the PCV with the purpose of a crankcase vacuum pump, which can aid ring seal. I suppose something like PCV could do this but you'd need much of the engine's intake airflow coming from the crankcase, rather than open to the atmosphere.
Old Mar 25, 2013 | 09:58 AM
lance m p's Avatar
lance m p
Default yes I thought it thru..........>
Yep I got it had to think on it for a minute, yes w/out a purge system it could create a problem-duh. I was only thinking of cleaning up the engine compartment a little bit-and I've had this turbo regal apart 3 times and yes the pcv valve DOES vent the crankcase! maybe I'm losing my mind? Thank youpcv going on!
Old Mar 25, 2013 | 10:19 AM
Mike Ward's Avatar
Mike Ward
Actually no. The vapours go back into the engine and are burned.
Old Mar 25, 2013 | 05:49 PM
lance m p's Avatar
lance m p
Default true a miss statment by me............>
you are absolutly right /a miss statement/
Old Mar 25, 2013 | 06:50 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Dude, calm down and just enjoy the car.
Old Mar 26, 2013 | 08:40 PM
lance m p's Avatar
lance m p
Default I am very calm?.......>
just a lil amp e, you can't pay no attention to me!
To I'm over thinking this simple ?
