I have been restoring the interior in my 81. Carpet, Door Panels, new leather seats mounted on new foam, etc...I am trying to find paint for the seat backs. It seems that there must be some paint for plastic out there that is color matched to the Medium Red interior that it has. Does anyone know where I can get paint for plastic to match the original color?? Thanks in advance for your response!!
I have tried that and it works OK, however, there are spots on the plastic that are chipped and showing the black plastic under the original paint. The dye does not cover the black spots.... If you had chips, how do you handle that?
Prime them first, using the primer made for use with interior dye.
Not sure what to repair the chips with, but as far as the black coming thru. Did you use the sealer(I think that's what it is) and the primer before spraying the dye?
When I did mine, it took quite a bit of the dye to get the coverage I wanted. Enough that I need to get more to finish up what I started.
Corvette America is a site sponsor so I'll toot their horn because I used their product. Buy the interior dye kit from CA. It includes the primer, adhesive, dye (color coded to match your year) and sealer. Use as directed; follow the proper steps and you'll get a beautiful and durable finish.
Vinyl dye will stick well to plastics or to other vinyl dye. It will not stick well to 'paint' or metal. 'Paint' is NOT the right product to recolor plastics/vinyl/leather/rubber. You need an "elastomeric recoloring agent", aka, vinyl dye.
If you have plastic items that have been 'painted', for best results you need to remove that paint before you 'dye' them. But, that's not so easily done.
I would suggest that you take the car to your nearest professional auto body paint supply store and ask someone to see what you have and recommend what needs to be done to correct your "problem".
i did all the plastic with this product it is really the least expensive, $13 for a large can, the most durable and easiest to use. just prep as if painting ( wax/grease, laquer thinner and shoot it) and mine is buckskin also which is SEMs color name too
Reason: more info
Okay! Great!! I have now gone through the steps of using the Plastic Prep as well as the Flexible Bonding prep, and have applied the dye. After "several" coats (1 can per seat), it is looking really good. I have ordered one more can of the dye to complete the project.
Next step, I am trying to order the leather 2" bolster seats mounted on the foam. It seems to me that Mid America is the only one who gets the fact that for '81, there was a red that was used exclusively on the '81. It is color code 752 and they want $900 for them. Is there anywhere else that I can get that specific color for a little less??????? No one else seems to realize that there is a specific red for that year....
