Help With 73 Interior Install
Old Mar 29, 2013 | 06:10 PM
gr8t73's Avatar
gr8t73
Default Help With 73 Interior Install
I am in the process of re-installing the interior of my 73 & in desperate need of the correct screws that attach the lower dash pads to the upper dash. These screws have a metal ferrel that prevent the screw from pulling through the vinyl when tightened. Does anyone know of a vendor that sells the correct screws?
Old Mar 29, 2013 | 06:15 PM
MrJlr's Avatar
MrJlr
Willcox sells entire interior screw sets......
I bought it when I did mine...sure helps!
Old Mar 29, 2013 | 06:32 PM
Steve's '73's Avatar
Steve's '73
Get the whole set, you'll probably need some other screw too or you may lose one down the road.
http://willcoxcorvette.com/product_i...ducts_id=26016
But, if you don't want to I believe these are the ones you are looking for:
http://willcoxcorvette.com/product_i...ducts_id=23839
Old Mar 29, 2013 | 07:48 PM
gr8t73's Avatar
gr8t73
I have three original screws & they have a different style ferrel than the willcox screws which is what most of the vendors sell. I would really like to find original style screws but that may not be an option.
Old Mar 29, 2013 | 08:29 PM
MrJlr's Avatar
MrJlr
It's possible the 3 you have are wrong?
The Willcox sets are very accurate......
Old Mar 29, 2013 | 09:31 PM
Steve's '73
Post a picture of what you're referring to. I have a feeling the ferrel you are referring to was actually part of the dash that came out due to wear and tear.
Old Mar 29, 2013 | 09:34 PM
gr8t73's Avatar
gr8t73
I think you may be correct I am sure that's a possibility anyway.
Old Mar 30, 2013 | 09:13 AM
Alan 71's Avatar
Alan 71
Hi,
The ferrel that's on the dash screws is part of the screw, not part of the dash panel.
The ferrel is compressed slightly during manufacture when it's installed on the screw. It should not be able to come off the screw; but should spin freely.
The purpose of the ferrel is to prevent the head of the screw from grabbing and twisting the vinyl slightly as the screw is tightened. It also helps prevent the screw from pulling through the dash panel.
Regards,
Alan
The screws with the ferrel are available.
Old Mar 30, 2013 | 09:56 AM
Steve's '73
Thanks Alan, do you have a picture of the screws with the ferrel compressed on?
I've taken my dash out numerous times and have never had the ferrel come out. Mine seem to have seized to the dash and no longer spin freely, so when I unscrew I'm actually unscrewing from the dash and ferrel.
gr8t73, are three of yours still embedded in the dash?
Steve
Old Mar 30, 2013 | 10:44 AM
DC3's Avatar
DC3
I know you said "correct", but, if you don't care about originality you can buy oval head stainless screws at Lowes or Home Depot with a matching finishing washer. Looks nice and works well.
http://www.lowes.com/Search=finishin...hing+washers#!
DC
Old Mar 30, 2013 | 01:29 PM
Alan 71's Avatar
Alan 71
Hi Steve,
Here are some pictures of the screws with ferrels that were used on the face of the right and left dash pads, and also two pictures of the screw (2 each side), that were used on the side of the dash pad on the hinge pillar.
There were also smaller screws that were used to mount the gauge cluster bezel to the dash pad. These were some times chrome and sometimes black oval head phillips screws similar to but shorter and smaller than the screws used on the face of the pads.
Regards,
Alan
Old Mar 30, 2013 | 01:52 PM
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
Originally Posted by Alan 71
Hi Steve,
Regards,
Alan
Alan!!! Is there anything you "didn't" take a picture of? Holy cow!
Terry
Old Mar 30, 2013 | 02:24 PM
MrJlr's Avatar
MrJlr
Terry
Alan...I'll take this if it's ok...
"No....no there isn't"
Old Mar 30, 2013 | 03:06 PM
Alan 71's Avatar
Alan 71
Hi,
Maybe those 5 pictures are 'new' this afternoon? Maybe?
Regards,
Alan
Old Mar 30, 2013 | 10:29 PM
gr8t73's Avatar
gr8t73
Alan like others here on the forum I am amazed at the extent of your knowledge & photo album. Any ideal if those
Old Mar 30, 2013 | 10:33 PM
gr8t73's Avatar
gr8t73
Sorry I didn't complete my response fat fingers problem. Does any of the vendors sell those Ferrels or screws with Ferrels?
Old Mar 31, 2013 | 12:18 PM
gr8t73's Avatar
gr8t73
Default Does anyone sell these
Hi Steve,
Regards,
Alan
Does anyone sell these screws with the correct ferrel
To Help With 73 Interior Install
Old Mar 31, 2013 | 01:22 PM
Steve's '73
The '73 AIM refers the ferrel as "eyelet", page 76 if you have the AIM.
Also has a note for the eyelets: "Paint body intr. trim color"
Dr. Rebuild lists a set of screws with eyelets, I'd give them a call:
A Screw & Eyelet 10 Piece Set 1466555 4.20
http://www.docrebuild.com/dr-r-web/DASH68A.PDF
Old Mar 31, 2013 | 07:37 PM
gr8t73's Avatar
gr8t73
Thanks Steve I will give Doc. A call tomorrow. I really would be lost without this forum.
Old Apr 15, 2013 | 11:51 PM
gr8t73's Avatar
gr8t73
So I ordered & received the screws from Doc Rebuild & just for everyone's information the. Dash screws do not come with the eyelets as the originals had. Just an FYI
