Overheating in an 80
Old Mar 31, 2013 | 11:00 PM
lbzdirtymax's Avatar
lbzdirtymax
5th Gear
Default Overheating in an 80
have a 1980, we just went through the motor, nothing crazy just freshened it up a little, little hotter ignition, headers, no head work, gm performance intake manifold. and a few other small things..
now the problem is that around town it gets to about 230* that's with an outside air temp of only 50*. on the hi-way it gets up to about 210 put some flexlite electric fans, didn't seem to do anything, pulled the thermostat, still nothing. the car does have a formula kit on it with a lower front clip.
any help on problem solving, or any ideas would help.
Old Apr 1, 2013 | 06:11 AM
7T1vette's Avatar
7T1vette
Are you sure the temp gauge is reading correctly?
Old Apr 1, 2013 | 07:12 AM
63split63's Avatar
63split63
Get an IR temp gun and verify the gauge reading .
Bill
Old Apr 1, 2013 | 07:24 AM
diehrd's Avatar
diehrd
Was the radiator removed when you did the engine ? Has it even been flushed ? Have you ever clean the cooling fins on it ?
Old Apr 1, 2013 | 08:58 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Was it over heating before you freshened it up?
Old Apr 1, 2013 | 10:42 AM
lbzdirtymax
5th Gear
Replaced the radiator with aluminum replacement, was not over heating before rebuild, also forget to mention we out a 700r4 trans in, will double check gauge and make sure its right.
Old Apr 1, 2013 | 10:51 AM
diehrd's Avatar
diehrd
I would also install a new thermostat just to cover that base.
Old Apr 1, 2013 | 11:01 AM
qwank's Avatar
qwank
water pump belt on correctly?
broken pump impeller?
is the fan shroud on?
Cracked head?
Old Apr 1, 2013 | 11:15 AM
lbzdirtymax
5th Gear
No thermostat, belts are all correct pump "looked" fine had heads gone through at machine shop. The fan shroud is there. I'm thinking its an air flow problem with that formula kit. But don't want to take it off
Old Apr 1, 2013 | 12:15 PM
qwank's Avatar
qwank
try using a thermostat. it is possible that the water is flowing through the radiator too fast and not being cooled. it's a stretch but you never know.
does the formula bumper have a chin spoiler to direct air up to the radiator?
Can you post a pic?
Old Apr 1, 2013 | 12:48 PM
lbzdirtymax
5th Gear
Ill get a good pic of it and put up soon
Old Apr 1, 2013 | 03:07 PM
BOSTONCAMARO's Avatar
BOSTONCAMARO
As qwank said, post pics...third Gen Camaros and Firebirds were notorious for overheating IF their flat air fence was missing...it was a flat panel that bolted to bottom of shroud to direct air upward...did you have that nose on it before? or is that also a new edition...(not the band)
Old Apr 1, 2013 | 07:03 PM
Mark_Milner's Avatar
Mark_Milner
Many times "equivalent" aluminum radiators are actually smaller than the copper/brass originals of cars. While they shed as much or more heat, sometimes they hold less coolant, and the coolant levels are not that much in a Corvette to begin with.
If you went to some of the racing design aluminum radiators, they are thicker across the core and they say that it hold more. But it is harder to get airflow through it and thus you overheat. Be sure it really moves air through the core.
Check for pressure leaks. Pressure dropping off will raise the temperature.
Old Apr 1, 2013 | 10:02 PM
SIXFOOTER's Avatar
SIXFOOTER
Got to go through the steps:
Radiator and shroud seals in place?
Air Dam in place?
What is your timing set at?
Is the spring in the lower radiator hose?
Unless you put on a johnny space rocket high volume water pump the problem ill not be to much coolant movement.
The air dam pushes air into the radiator while your driving. If the seals are not all there to block the gaps around the radiator the air will bypass the radiator, negating it.
If you put on electric fans, they should be pulling air through the radiator when they come on, same deal with the seals, the fan setup has to be sealed to the radiator for it to pull all the air through the rad. Are your fans running the right direction?
Old Apr 1, 2013 | 10:41 PM
lbzdirtymax
5th Gear
Yes electric fans are pulling air, ill get to the shop in the morning and make sure all the seals are there. Is there a good website that shows the correct placement?
To Overheating in an 80
