Changed rear diff fluid , Question
Old Apr 3, 2013 | 07:13 PM
cb98coupe's Avatar
cb98coupe
Default Changed rear diff fluid , Question
I had the fluid changed on my 1979 with stock rear end . Went ahead and did as recommended . 2 bottles of the GM fluid with one bottle of additive . My mechanic said it was low and I did not have any more fluid . Do I need to add or is a little low ok . Everything seems ok . Please chime in .
Old Apr 3, 2013 | 07:27 PM
mds3013's Avatar
mds3013
Mine takes a little more than two bottles to fill. Of course it depends how much you can get drained or pumped out before refilling. With the car level, the lube should be at the bottom of the fill hole just short of running out. I filled mine with the front slightly lower than level and I probably have 3-4 oz. more then required. I would fill it to the bottom of the plug. mike...
Old Apr 3, 2013 | 08:07 PM
cb98coupe's Avatar
cb98coupe
Thanks mike , so do you think I am ok with the two bottles as recommended . I don't want to go back to the shop and put it on the lift again unless its absolutely necessary . Chris .
Old Apr 3, 2013 | 08:23 PM
mds3013's Avatar
mds3013
I can not answer that for sure. I would not want to run mine low on lube. Check into removing the plug to see if you get any lube to run out of the hole when the car is level. Some of the other Members may have a better idea. mike...
Old Apr 3, 2013 | 08:36 PM
cb98coupe's Avatar
cb98coupe
I don't want to be overly compulsive about little things but I don't want to be foolish either . Am I risking serious damage by just leaving it at 2 plus one additive . The reason i changed it is because of some chatter but now its gone .
Old Apr 3, 2013 | 08:46 PM
Redwing01's Avatar
Redwing01
2015 C3 of Year Finalist
Like mds said, level surface and filler up!
No noise is good , you'll get the feel of it.
Best of luck and enjoy.
Old Apr 3, 2013 | 09:06 PM
cb98coupe's Avatar
cb98coupe
Thank you !!!! I guess I will bring it to this really good shop that I have used and have them check it .
I should have brought it to them in the first place but I had the fluid and had a local mechanic do it .When he brought it back he said it seemed a little low .
Old Apr 3, 2013 | 09:07 PM
flyeri's Avatar
flyeri
Mine took the two bottles of GM lube plus the additive and I still needed a couple ounces of lube. Luckily I had another bottle on the shelf. I would add some more if I were you.
Old Apr 3, 2013 | 09:13 PM
Redwing01's Avatar
Redwing01
Good luck , don't be afraid to crawl under there and give er a go too. You'd be surprised at the savings for a little research!
It's a stinky , ****** job doing the read end lube though so have lots of rags handy... Ask me how I know!!!
Old Apr 3, 2013 | 09:27 PM
gcusmano74's Avatar
gcusmano74
On my '74, I have crawled under the car from behind to check and top off the diff.
"To succeed, one must be more persistent than one's opponent."
Old Apr 3, 2013 | 09:47 PM
cb98coupe's Avatar
cb98coupe
i am gonna buy another bottle tomorrow but I should be ok for a little bit ????
Old Apr 3, 2013 | 10:57 PM
texas jim's Avatar
texas jim
Just get another bottle of diff. oil and another bottle of additive, then measure and add the right amount of each (correct ratio) to top it off. No need to bring it to a shop and pay them. Spend that money on the oil and additive.
Old Apr 3, 2013 | 11:14 PM
cb98coupe's Avatar
cb98coupe
Texas Jim , In your honest opinion do you think I really need to add more fluid or am I ok at this point .
Old Apr 4, 2013 | 12:37 AM
tracdogg2's Avatar
tracdogg2
You need to add more fluid. Running it low is starving the stub axle bearings and makes it harder for the fluid to circulate.
Mike
Old Apr 4, 2013 | 06:32 AM
cb98coupe's Avatar
cb98coupe
Mike
Ok will do , I am definitely getting another bottle today . Thanks .
To Changed rear diff fluid , Question
