Header Choices (Questions!)
Old Apr 4, 2013 | 07:30 AM
MrJlr's Avatar
MrJlr
Default Header Choices (Questions!)
I am at the point that it's time for some headers...woohoo !
I am sure I want ceramic coated for heat reduction.
1974 Coupe - 350 L-48 Automatic with AC.
So....right to the questions...!
1) Long tube or short tube ?
2) Brand/Model ?
3) Best fit without have to "dent" anything ?
4) I still want to be able to get to my spark plugs !(not really a ? !!!)
5) I have AC.....issues ?
6) Other considerations ?
I'm not looking for the cheapest headers out there...nor the most expensive.....I don't mind paying for quality as long as everything works out ! I will trade money for headaches !
I suppose it goes with out saying that this is about adding horsepower...!
Thanks in advance!
Old Apr 4, 2013 | 08:16 AM
diehrd's Avatar
diehrd
Ya want us to link ya to the deals , maybe put them on and check for leaks to.
Search is your friend , matter of fact ebay would be a good place to start .
Old Apr 4, 2013 | 08:29 AM
MrJlr's Avatar
MrJlr
Um.....wow.
I don't need comments like that.
If you see a question from me - feel free to stay away....
I am looking for answers from helpful people....not your BS.
(oh....I can toe tap too...!)
("TOO" is spelled TOO... grammar check.)
Old Apr 4, 2013 | 08:33 AM
Indiancreek's Avatar
Indiancreek
Don't know, but will be interested in the input with the folks with experience in this area. Can't beat the input from those who have turned the bolts.
billcarson's Avatar
billcarson
i put in Hedman 68308 long tube hedders and they fit with no denting anywhere.i have no a/c or smog pump but i do not believe that would affect fitment.they were around $350. hd flanges and good quality.good luck.
Old Apr 4, 2013 | 08:36 AM
MrJlr's Avatar
MrJlr
Exactly...!
Old Apr 4, 2013 | 08:38 AM
MrJlr's Avatar
MrJlr
I just Googled those.....they look real nice!
Is yours a L-48 ?
Old Apr 4, 2013 | 08:45 AM
billcarson's Avatar
billcarson
yes an L48 i'll look for a picture.
Street Rat's Avatar
Street Rat
I got a set of used ceramic coated Hooker Competion headers on fleaBay. They fit perfectly with no denting. The plugs are a breeze to get to as well. I was suprised at how easy they were to install and the price was right. I ended up buying the matching Hooker exhaust system and turbo mufflers from Summit Racing. It bolts directly to the headers and runs all the way back. I'm very happy with the setup.
Old Apr 4, 2013 | 08:52 AM
AirborneSilva's Avatar
AirborneSilva
You sure seem to be an angry person, Ive not see a helpful post from you yet! As MrJlr has said anytime you see a post and or thread from me just ignore it!
Even a moderator has said that the search function is hit or miss at best! These forums are for HELPING each other
Old Apr 4, 2013 | 08:53 AM
billcarson's Avatar
billcarson
Old Apr 4, 2013 | 08:56 AM
AirborneSilva
Great looking headers Bill, thanks for posting the pics
Old Apr 4, 2013 | 09:02 AM
MrJlr's Avatar
MrJlr
Yes Bill, those do look awesome!
Good ground clearance too......
They might be a perfect solution
No problems with spark plug access etc ?
Old Apr 4, 2013 | 09:09 AM
jaybird81's Avatar
jaybird81
Bill, those do look nice. I looked them up and it says the finish is thermal coated. Does that mean the great looking finish holds up to the heat? I had a set of hooker headers years ago on a car in high school that the black paint just burned off when I first started the car and they looked horrible ever since.
Old Apr 4, 2013 | 09:11 AM
Citation X's Avatar
Citation X
Rather than ceramic coat you may want to check Jet Hot treating. Never chips, cracks,
peels rust and does a great job of heat reduction.
Old Apr 4, 2013 | 09:16 AM
billcarson's Avatar
billcarson
no plug issues but i have stock heads.
Old Apr 4, 2013 | 09:17 AM
MrJlr's Avatar
MrJlr
My heads are stock too.....awesome!
To Header Choices (Questions!)
Old Apr 4, 2013 | 09:22 AM
FLA-C3's Avatar
FLA-C3
Active Streak: 90 Days
<------ I had them coat the Hooker comps on the 408 small block in my 73. They look great and fit with no modification.
Old Apr 4, 2013 | 09:53 AM
Steve's '73's Avatar
Steve's '73
I've had Hooker 2456-1HKR on my L-48 350 for ten years now, no issues. No need to dent and plugs are easily accessible.
Remove the plugs, jack up the car, install from the bottom, reinstall plugs
Old Apr 4, 2013 | 10:12 AM
F22's Avatar
F22
I have a set of generic headers, no idea where they came from, but look like Hookers (well, not literally...) and with the aluminum L98 heads, I can no longer remove the driver's rear plug or the passenger side front plug because these heads have angled plugs. You'd have to remove the headers to get to them, or get a special socket or wrench that would fit under those bends.
Found this out last night, so I'm going to peruse the Snap On catalog I just got. Also going to have to go to copper header gaskets too, as there are exhaust leaks at the flange. Nothing that can't be solved by throwing money and time at it!
Just a consideration for your future build-up, whether you go with the aluminum heads on the L48, or go with a crate motor!
