Steering column removeable hel needed
Old Apr 12, 2013 | 09:46 PM
nelson007's Avatar
nelson007
Default Steering column removeable hel needed
Hello all,
Need help in the removable of the steering column in a1970.Are the only things I have to do is:' remove the cable going to the column,the the two bolts going through the fire wall and the black plate , and the two bolts to the dash. How do I remove the black plate that is on the column that is next to the
Does the black plate come off when I remove the column?
Thanks in advance,
Nelson 007
Old Apr 13, 2013 | 01:21 AM
Alan 71's Avatar
Alan 71
Hi Nelson,
The bolts you list will release the column from the car. Remember to remove the rag joint if it's still hooked to the column shaft
The 'plate' on the engine side of the firewall will come off (there's sometimes sealer on it that holds it in place) once the column is out. The 'plate' on the interior side of the firewall is part of the column itself.
Remember there are electrical connections on the column from the dash harness that will need to be unhooked as you take the column out.
Good Luck!
Regards,
Alan
Old Apr 13, 2013 | 01:30 AM
CraigH's Avatar
CraigH
Hi Nelson
Alan is correct re the steps.
Have a look at the bottom of the page linked below where I have images of each step to get it out.
http://forums.corvetteforum.com/c3-g...ourney-13.html
Craig
Old Apr 13, 2013 | 07:50 AM
nelson007's Avatar
nelson007
Thanks Alan and Craig,
I will give it a try today.
Nelson
To Steering column removeable hel needed
