A/C Compressor won't shutoff
Old Apr 14, 2013 | 02:08 PM
72 Stinger's Avatar
72 Stinger
Default A/C Compressor won't shutoff
My A/C compressor continues to run when the dial is in the off position on the controller on the console. It does shutoff when the dial is swicthed to heat, vent and defrost. The car is a '72 Coupe. Any suggestions?
72 Stinger
Old Apr 14, 2013 | 05:47 PM
7T1vette's Avatar
7T1vette
One of the little 'finger' contacts on the side of the heat/vent control head is not adjusted properly. Once you dig into the trans tunnel and pull that unit out (a PITA to do, unfortunately), you can make adjustments as needed to get the contacts to work as expected for each set position.
It is also possible that those contacts have 'welded' together...but unlikely. If so, separate them and use file or sandpaper to smooth them back to good condition.
Old Apr 15, 2013 | 07:56 AM
Roco71's Avatar
Roco71
I had this problem although my compressor was not hooked up the line to it was always hot. In my case it turned out to be the terminals to the anti dieseling relay (located behind the passenger dash) where corroded. After cleaning them it worked fine.
Old Apr 15, 2013 | 11:49 AM
7T1vette's Avatar
7T1vette
Interesting! Yes, the A/C clutch was engaged for a short time when the engine was turned 'OFF' so that the extra load on the engine would stop it. If that relay stuck 'open', that problem would occur.
P.S. You can take the top off that relay and clean those contacts. Much less expensive than buying a replacement. Put a bit of dielectric grease on those contacts if you repair it.
Old Apr 15, 2013 | 02:05 PM
72 Stinger's Avatar
72 Stinger
Thanks, I'll look into it.
Old Apr 15, 2013 | 02:10 PM
Roco71's Avatar
Roco71
I opened mine up and it look like new inside. I just cleaned the terminals and it starting working correctly.
To A/C Compressor won't shutoff
