Which A/C compressor is correct for '72 350?
Old Apr 15, 2013 | 07:33 PM
STL Zombie Hunter's Avatar
STL Zombie Hunter
St. Jude Donor '13
Default Which A/C compressor is correct for '72 350?
I have a few books that say compressor # 1131002 (green sticker) is correct, and have also seen # 5910793 (red sticker) as the correct one.
I believe these compressors are the same for small block and big block, with the exception of pulley size. 5" for SBC & 6" for BBC??
Any thoughts on this??
Old Apr 15, 2013 | 07:42 PM
Tom73's Avatar
Tom73
My parts exchange manual says part number is 6598452. Was used in 72 and 73.
Tom...
Old Apr 15, 2013 | 07:47 PM
STL Zombie Hunter
St. Jude Donor '13
Lets add a 3rd # to the mix.....ugh!
6598452
Thanks Tom
Old Apr 15, 2013 | 08:18 PM
62corvette's Avatar
62corvette
I went out to the garage and checked for you--two unmolested 72 a/c cars. Both have green stickers. Both are dated right for the car.
454: vin 89xx. part number 5910797, 6" pulley. Car has October 15 trim tag, compressor is dated 091612 (September 16, 71, 2nd shift)
350: vin 131xx. Compressor no. 1131002 dated 012021. (January 20, 72, first shift). 5" pulley. Car has February 4 trim tag.
Both of the compressor part numbers agree with the NCRS judging guide chart for compressors.
Old Apr 15, 2013 | 08:55 PM
STL Zombie Hunter
St. Jude Donor '13
Thank you so much. My Richard Prince book seems to be correct in this case. It stated that 1131002 is correct for 72's with 350ci.
Do you believe this will also be correct for a day 1 build date (August 16, 1971)?
Now I just need to find one. Soooooo, where do you live & do you keep your garage unlocked.
Thanks again for clearing this up for me.
Old Apr 15, 2013 | 10:35 PM
62corvette's Avatar
62corvette
I would guess correct that early as well.
Sure, door is unlocked. You can help. 350 car needs head gasket, 454 car needs dash wiring.
Old Apr 16, 2013 | 09:53 AM
STL Zombie Hunter
St. Jude Donor '13
Cool. I'll bring my Harbor Freight tools and a big empty box for spare parts
If you get time this week, can you take a few close up pics of your SBC compressor please? And also the brackets if they are visible.
You can just PM them to me if you like.
Thanks in advance! I really appreciate it.
Michael
Old Apr 16, 2013 | 06:46 PM
flaco1801's Avatar
flaco1801
Never knew there was a date on compressor...where is it located? thanks
To Which A/C compressor is correct for '72 350?
