removing speedo cable
Old Apr 17, 2013 | 06:46 AM
wagggawoo's Avatar
wagggawoo
Cruising
Default removing speedo cable
I can't seem to disconnect my cable from the the instrument cluster. I can't see it, but it feels like there is no connector back there, can I disconnect it from where it is connected to a junction box on the left wheel well, under the water tank for the wipers?
Old Apr 17, 2013 | 07:35 AM
mariobro's Avatar
mariobro
I just replaced mine on my 72. There was a retaining clip, all I had to do was push the clip toward the speedo (clip does not get removed) and the cable slides straight out the back. I laid on my back with a light under the dash when I did mine. Good luck.
Old Apr 17, 2013 | 08:33 AM
speedreed8's Avatar
speedreed8
that junction box is the cruise control transducer, if youre having problems alot of times that where the problem is not the cable., some have done as i did, replace the 2 piece cable with a single cable .
To removing speedo cable
