How fast is too fast?
Old Apr 19, 2013 | 06:03 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
drone, heat, gas sucking
other than that, it runs fine.
Old Apr 19, 2013 | 06:30 PM
alswagg's Avatar
alswagg
What is the big deal? We run our Small block Chevy's 4,500 all day long in our boats. I mean for hrs 6 to 8 when we run North and South of Lake Michigan. Hi Rpm's are not a problem, lugging the engine is. Al
Old Apr 19, 2013 | 06:37 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
true enough.
what is the TBO on a marinized 350?
1000hr, 65,000 miles?
heat, marinized run what, 160? 180 with closed system?
vs 210 in a car.
forged internals and stout crank vs cast 2 bolt
cam slightly different.
Old Apr 19, 2013 | 06:38 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by 71scgc
We've all gotten too used to OD.
You wouldn't have flinched at those revs in 1970.
Carter
Bingo!!
Old Apr 19, 2013 | 09:23 PM
flyeri's Avatar
flyeri
Originally Posted by Mid-Years Forever!
Yes, we have, but you make that sound like a bad thing.
I share the OP's concerns.
I like the idea that OD can reduce:
1. Wear and tear on the mill.
2. Noise. (I like headers & pipes--I don't like D-R-O-N-E, for 6 hours, one way).
3. Gas consumption.
I've seen mention of both Tremac and Richmond trannies, in both 5 and 6 speeds. I like to shift, so I'd like a 6 speed.
My Questions:
1. Cost of Tremac 5spd conversion? 6spd? (Parts only--my labor).
2. Cost of Richmond 5spd conversion? 6spd? (Parts only--my labor).
3. What 5spd is in early '80's Z28's? I read (here) it was a Tremac, and that buying a rusted out Z28 for hundreds of dollars would be, by far, the cheapest conversion. Discuss?
4. When doing these conversions, are new cross members available? And I'm guessing I get to drill new holes? Or are the cross members engineered to use the existing holes in the frame.
Thank you.
Tremec TKO600 .64OD and new Centerforce DF clutch, machined flywheel cost me about $3600 with my labor. I had a cracked bellhousing so I bought a new one. That is not included in the above figure. I also wanted to cut the crossmember and I paid to have a little welding done.
The kit comes with a bracket to mount trans to the crossmember. I drilled no new holes.
Best money I have spent on the car by far. We take it on day trips to the mountains now as much as the C5.
Old Apr 19, 2013 | 09:51 PM
alswagg's Avatar
alswagg
Originally Posted by calwldlife
true enough.
vs 210 in a car.
Actually we are seeing well over 2,000 hrs on engines, and true temps are usually around 180 to 195 on closed systems. Yes the cams are slightly differant, specifically the Exhaust timing.. Most are upwards of the 300 hp mark. Are you saying marine engines are better than auto??? Better than our prized C3's. Don't say it so Joe. Oh ya, current production blocks are much better than our antiquated C3 blocks/rotating assy;s Al
Old Apr 20, 2013 | 02:18 AM
Mid-Years Forever!'s Avatar
Mid-Years Forever!
Default Thank You....
flyeri,
Thank you, very much, for the mechanical and financial breakdown of your conversion.
And I'm really pleased to hear how satisfied you are with it--I would be too!
Now I must reveal my ignorance (which gets easier with repetition ): Is your TKO a 6-speed or a 5-speed? I did some Googling and all I could find were sales pitches, but no specs.
And did your gasoline consumption change noticeably?
Thanks again.
Peter
Old Apr 20, 2013 | 07:16 AM
diehrd's Avatar
diehrd
All this talk they where built for it ... LMAO .... They where built with available parts of the day and most cars back then did not see 100,000 miles before serious work was done to them.
Get into a newer computer controlled car and if you don't get 200,000 miles out of them your doing something wrong.
Put an O/D in it OP and you will be a lot happier and so will your car.
Old Apr 20, 2013 | 07:30 AM
oldschoolvette's Avatar
oldschoolvette
not sure where you were in the "DAY" but oil had zinc in it and if you changed it every 3K, things were good. We had a 69 chevy truck at my uncles shop with BBC and it ran about 300K before we tore it down for an overhaul.
Old Apr 20, 2013 | 08:15 AM
diehrd's Avatar
diehrd
Usually these old motors where lucky to see 100k with out serious work and those who want to chime in I had one or I knew of one are just exceptions to the reality of that time period.
So my "Day" spent in a transmission business allows me to have first hand experience , lets not forget why people ask the buyer of a used car how many miles on her ,,, that came about from back in the "day" where now a 150k is considered a lot but we expect she will give up 50k or more before an overhaul.
Old Apr 20, 2013 | 09:56 AM
71scgc's Avatar
71scgc
3. Gas consumption.
My Questions:
Thank you.
Not a bad thing, just a fact.
My car has a TKO-600 and 3.70 rear. TKO-600 is well suited to the 3.70 rear. Years ago, before these conversions were common, we would sit around and talk about how this would be perhaps the greatest thing you could do to old cars. By years ago, I mean late '80s,
which was also the last time I owned a car without OD.
The switch was one of the first things I planned to do to my car when I bought it. I'll never go back to the slushbox, but will keep it anyhow.
Again, not a bad, but very good thing!
Carter
Old Apr 20, 2013 | 01:41 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
Originally Posted by Solid LT1
2 words:
FIVE SPEED!
End of discussion
Made my project more enjoyable in today's economy and technology-infused environment.
Carter
The h311 of it is, back then, 101 octane leaded gas was only 33 cents a gallon and available everywhere...
Old May 19, 2013 | 08:49 AM
  #33
Invader Sandstone's Avatar
Invader Sandstone
I am gettin 2,700 rpm at 70mph and was nervous running like that for 20-30 minutes. Did a search to see how scared I should be, and now I know it's not a huge deal. I want to switch to a OD tranny but don't have the pockets for one yet.
Old May 19, 2013 | 11:17 AM
  #34
my 76 ray's Avatar
my 76 ray
Just for the heck of it I crunched a few numbers about the cost of converting to overdrive vs paying for the gas.
I assumed 15 MPG without OD and 20 MPG with OD with gasoline costing 3.75 per gallon.
I also assumed it cost $2500 to install the OD. Based on those assumptions it would take 30,000 miles of highway driving to save the cost of the installation in gas.
I saved the spreadsheet to do the calculations so if somebody has more realistic numbers to plug in I can do the math ... for a few.
Old May 19, 2013 | 11:22 AM
  #35
Invader Sandstone
That's pretty damn useful, thanks.
Old May 19, 2013 | 12:09 PM
  #36
gcusmano74's Avatar
gcusmano74
I agree. The only problem with turning that much RPM is noise and fuel consumption. Won't hurt the engine.
