thd400 to 200r4
Old Apr 19, 2013 | 05:11 PM
terrys6t8roadster's Avatar
terrys6t8roadster
Default thd400 to 200r4
Can't seem to find the first gear ratio in the 69 turbo 400. The car has 3.08 gear set, the first gear ratio in a 200r4 is 2.74. Don't want to make the car any more of a pooch from the stop lite. Any body with a lite to shine on this? terry
Old Apr 19, 2013 | 06:36 PM
diehrd's Avatar
diehrd
http://www.chevellestuff.com/tools/rpm_calculator.htm
Old Apr 19, 2013 | 09:23 PM
redwingvette's Avatar
redwingvette
Here is info on my install.
200-4R install
200-4R: 2.74 first, 1.57 second, 1.00 third, .67 fourth
Turbo 400: 2.48 first, 1.48 second, 1.00 third.
Old Apr 20, 2013 | 03:57 AM
terrys6t8roadster
200-4R install
Hi yhanks for info, what's your opinion of the 200r4 over the original tranny?
Old Apr 20, 2013 | 06:22 AM
scottw's Avatar
scottw
If you do a search here, a lot of guys have made the swap and like the increase ratio in the bottom and can't say enough about having an OD.
Old Apr 20, 2013 | 08:33 PM
7T1vette's Avatar
7T1vette
It depends on why you are making the swap and what else is in the drivetrain.
Old Apr 20, 2013 | 11:29 PM
Vette5.5's Avatar
Vette5.5
Another thing to consider is a 700R4 trannny, as has a 3.05 1st gear, and the the same od 4th 0.70, as the 200. Maybe a good way to get a little deeper 1st ratio, without changing out anything else. Done 700R4 swaps myself, and do require the driveshaft shortened a bit, but no big deal.
To thd400 to 200r4
