Stuck Throttle
Old Apr 27, 2013 | 12:01 AM
68vxm's Avatar
68vxm
Default Stuck Throttle
Experienced an interesting few seconds several days ago. I was pulling away from a stoplight, and being first in line, I stuck the gas pedal on the floor. When I hit the clutch and lifted the gas to shift from second to third, the motor revved to redline, and I realized the throttle was stuck wide open. I killed the ignition and the motor died. The pedal was still on the floor, but after a few pokes with my foot, the pedal popped back up. Got home with no issue. I didn’t see anything wrong with the throttle cable or return springs, and it didn’t look like anything was binding under the dash. I was able to duplicate the problem (without the motor running), and determined that the pedal was catching where the carpet transitions from carpet to the plastic padded area under the pedals. Very subtle, but just enough to hold the pedal down. I had installed new carpet recently. I was able to trim the area to create a smooth transition rather than a step. Lesson learned. Experiment with a few dead “gas pedal on the floor” excursions before you do so under power.
Old Apr 27, 2013 | 12:13 AM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Good tip, glad you and the car are okay.
Old Apr 27, 2013 | 12:15 AM
MakoJoe's Avatar
MakoJoe
Yea it can happen where it will get caught. Last time it happened to me I sent my 1976 Chevelle Malibu Classic into a Tranny Shop for a tranny rebuild and they did not hook up my throttle linkage properly. Was driving out of shop and darn throttle got stuck in almost full throttle since I was testing out the Shift Kit I had them install. Glad I was on a side street and shut off the car. Pulled the hood and fixed the problem myself after I saw they did not hook the linkage up properly.
Old Apr 27, 2013 | 12:55 AM
my 76 ray's Avatar
my 76 ray
I had a clip on a carb linkage rod come off and it caused my throttle to stick at almost full throttle. I did exactly what 68vxm and MakoJoe did. Shut the engine off. Isn't it scary that when Toyota was having problems with the throttle sticking there were people who were going 100 mph for long distances trying to stop the car with the brakes.
Old Apr 27, 2013 | 01:03 AM
TimAT's Avatar
TimAT
The thing with the Toyota just proves that people have lost the capability for common sense. But on the other side of that, some cars, if you turn the key to OFF, the steering locks. Or at least people THINK it's locked since to power assist goes away.
Old Apr 27, 2013 | 01:38 AM
MakoJoe's Avatar
MakoJoe
Sad thing in my case was they did not know how to reattach the linkage properly to the carb after rebuilding my tranny. Me non ASE certified I fixed it in a few minutes. Now I am not bashing any people but this dude made a major mistake when putting my car back together and I almost crashed my Chevelle because of it. Glad I was on a side street after I pickup my car.
To Stuck Throttle
