Cross member question
Old Apr 28, 2013 | 01:16 AM
Skip Burney's Avatar
Skip Burney
Default Cross member question
Who has cut their crossmember and changed it so that they could pull the transmission easier and then bolt the crossmember back in. Thanks Skip
Old Apr 28, 2013 | 09:45 AM
edk136's Avatar
edk136
My dad cut his on his 1966 Vette when he put the SS700 in. He cut the crossmember at an angle just outside of each exhaust tube. Added flanges and uses 3 bolts on each side to secure it. I will say it made installing the SS700 much easier but I still have mixed feelings doing that to an original car. Also I don't know if the C2's have more or less room than the C3's in the area where the cuts were made, so this might not be the easiest way to cut the crossmember on a C3 with the body on.
Old Apr 28, 2013 | 02:19 PM
69 Convertible's Avatar
69 Convertible
I've done it on my 69 vert. I put in a 5 speed. With the recommendation from other members, I pulled the plug. Bull shark had some pics that I copied from. But he had access to a cutting machine and made a nice flange that was welded to the crossmember. I did mine a little different. His has the matching hole in the crossmember, mine I made as a whole plate. If you do cut the crossmember, make sure you measure the distance of the trains mount from the drivers side to the mount bracket and then from the passenger side to the trans mount. It different on both side. That way when you go to have it welded, it would be it the right place. The trans mount is not centered on the crossmember as I found out later.
Old May 11, 2013 | 03:13 PM
rehirsch8's Avatar
rehirsch8
Here's mine:
Old May 14, 2013 | 07:48 AM
Super6's Avatar
Super6
I did it in a vary similar way, also on a 69 convertible, but I removed a much shorter section because I have plans to stiffen up the frame using roll-bar tubing welded to the crossmember stubs on either side of the removable section. I also angled my flange plates in a little at the bottom to give a "V" shape. This way you can set the removable section in place and it stays there on its own while you install the bolts. There's a picture of the finished product in "My Corvette Photos".
To Cross member question
