Hi all,
I have a 1970 small block and need a new battery and would like any advice. I've done some research and hear good things about Costco's Kirkland (Interstate) battery and their great warranty, etc. They say their book has two options, one with 875 CCA and one with 1000 CCA.
Does anyone know which one I really need?
Any comments regarding the Kirkland battery?
Anyone have a good battery trickle charger/battery tender they would recommend that isn't super expensive?
I've had success with Interstate and Die Hard (Sears) batteries. I would put the battery with the most CCAs in it. Right now I'm using an Optima Red top. I won't buy another one though. I've had that thing on a charger quite a bit after working on the car with the doors open. It seems to drain down too quickly to suit me.
do some research and you will find there is only 3 manufactures in the world who make car batteries. the biggest thing you need to make sure is that it will fit in the battery box and you can use the mounting hard wear. do you drive your car in the cold?
Go for a Costco Kirkland brand battery and be happy. If you have a warranty problem they don't argue and want their customers happy.
Walmart's Maxx batteries are good as well but their shop guys suck...have no idea what they're doing. They won't hassle you with a warranty claim though.
Sears Die Hards have been up and down in quality over the years. I understand they have a different vendor now and quality has much improved.
There's a number of battery tenders on the market...dollar for dollar get a Battery Tender Plus.
Go to Autozone and pick up an Autozone battery with about 825CCA for $119 and a nifty little warranty and be done with it.
Way better than the deep cycle boat battery that came in my car!
I am going to buy the least expensive battery for my car.....I have been through countless Optima's and every other trick battery in various cars... for the Corvette, I will get an Autozone special...
Costco 875 amp-hr battery or Wal-Mart equivalent will do you just fine. Anyone spending more than that on a battery for their car is just wasting their money.
Goona say a 1000 cca battery is is 10'' rather than the more more common 8". Big battery, and really can't see why you'd need this. Nothing wrong with an Autozone or Advance Auto Gold battery, as what I use. Usually go Advance, as can order online, for later store pick up for 20% discount. Top warranties on these batteries too. For mantainers, while not the cheapest, have Ctek 3300's, and only thing I use for all 12v batteries. Patented multi step charging, can survive a dunk in the lake, or running over. Don't laugh, it happens.
The 74' came with a Wal Mart battery from 2009 and it had sat for at least two years and that same battery is starting my 'vette up, every single time, without hesitation.
IMO, best thing you can do is install a battery cutoff switch and turn it off if you are not going to drive for a week or two. I have a blade type on sidepost for my '95 and one that unscrews with a **** for the '68 top post. Both cars started right up this spring after being stored since October in freezing weather without a tender. If you do use a tender, I prefer a 2amp unit put on a christmas tree light timer and run it once a day for an hour, not all the time. Have seen them overcharge and boil out making a mess...
I just get the cheapest at Walmart. You don't need anything robust. They have the best warranty too.
Used to use Kirkland, but switched to WM.
Also use a cutoff switch.
My in-laws live in Arizona. The first time I visited them I commented on the huge number of tire and battery retailers I saw...it seemed every street corner had a battery/tire seller of some name.
My dad-in-law said it's due to the heat there...batteries (and tires) simply don't hold up in that kind of heat. He said that no matter what brand battery you buy and no matter what the cost or quality level, they last two years before replacement is necessary. The environment just bakes them in short order.
Tires wear out more quickly in that heat as well. It's just something they just have to deal with.
Response to Gungatim:
Disclaimer up front that I do NOT work for these guys--Deltran Battery Tender. I think the name is misleading. It should be "maintainer" because you plug this in and walk away. There is circuitry that shuts the device off when it reaches a full charge. Then as the battery loses charge it will come on again and shut of at full charge. It will continue to do this. Plug and play. Month after month and no timer to set. No danger of boiling over or exploding the battery. I plug my car and motorcycle in all winter, forget about it, and never had a problem. Here's the link: http://batterytender.com/products/automotive.html
i have had nothing but trouble with walmart batteries. they only last 2-3 years then die. the best batteries i ever had were delco but can't find them anymore. they always lasted 5 years without trouble. i just got my first interstate battery. i heard they are great. guess i will see.
The Del-Tran battery tenders work great. I use them on all my cars and bikes. I like Delco and Interstate batteries. Just because there are only a couple of battery manufactures doesn't mean all batteries are the same. They are made to the specs of the retailer and I am sure some are trying to save a few bucks buy making them cheaper.
