About sport mirrors...
Old May 1, 2013 | 05:43 PM
Peterbuilt's Avatar
Peterbuilt
Default About sport mirrors...
I have a chance to buy a set of 78 sport mirrors but my 74 has no mounting place on the door panel so my question is if I remove the cables will the mirror stay in a set position or just flop around?
Thanks, Pete.
Old May 1, 2013 | 06:18 PM
v2racing's Avatar
v2racing
It will probably flop around. It has to be free enough for the tiny cables and lever to move it, so I wouldn't think it would have enough resistance to stay put on it's own.
With careful measuring you can cut the holes necessary to mount the remote lever in you door panel.
Old May 1, 2013 | 06:25 PM
obas's Avatar
obas
I put them on my 75 and they stay in place with the cables tucked in the door.
Old May 1, 2013 | 06:28 PM
Shark Racer's Avatar
Shark Racer
*edit* my bad.
You need the cable on a mirror that was designed to use it..
Old May 1, 2013 | 06:33 PM
BDoc's Avatar
BDoc
I'll trade you my 78 doors for your 74 doors
Old May 1, 2013 | 07:09 PM
Peterbuilt's Avatar
Peterbuilt
Tucked inside the door, that could work.
My Vette just turned 39 today (built May 1, 1974).
Just got new door panels so I'm not going to try to make a hole in it.
The mirrors that I have are chrome sport mirrors from advance, had them for several years and
they are starting to flop around.
Advance has black ones that are the same size and shape so the holes will line up but I'm not sure if I can match "Classic White" from a can.
A forum member has 78 sport mirrors in white so I'd like to buy them, and that's why I was wondering about what to do with the cable.
Thanks for the suggestions.
Pete.
http://shop.advanceautoparts.com/web...hedFrom=header
Old May 1, 2013 | 08:00 PM
v2racing's Avatar
v2racing
Originally Posted by Shark Racer
The question was about a mirror, not the handle. The mirror itself won't flop around, but the control will be hard to use.
Read my post again. I am saying the mirror will flop around without the cables connected to it. The mirror moves too easily without them. The mirror has to to be able to move freely for the tiny cables and lever to move it.
Old May 1, 2013 | 08:37 PM
Shark Racer
d'oh. I didn't make the connection.
Sorry about that. Fixed my post.
Old May 1, 2013 | 08:44 PM
Peterbuilt's Avatar
Peterbuilt
OK I think I got it. Leave the cables connected and tuck them in side the door and just push the mirror to adjust it.
Thanks, Pete.
Old May 2, 2013 | 08:09 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Don't cut anything. My 74 had sport mirrors on it with the driver's side remote toggle.
Sport mirrors mount with studs over the position of your original chrome mirror. Be aware putting the nuts on the studs inside the door is a real bear. Any 77 and later AIM shows how the mirrors install and how the remote cable routes around the window channel.
Toggle and bezel mount on the interior door panel.
Old May 2, 2013 | 12:34 PM
Korevette's Avatar
Korevette
My '76 had at some time sport mirrors installed to make it look like a '77 and newer. It took me a bit to get over the original long chromed pedestal mirror(s) but I have gone back to them.
I could not tell where the donor 'sport mirrors' came from but it was a GM car, maybe a Trans Am... What I did notice is the sport mirror 'pedestal' appeared to shorter that the original chromed pedestal and restricted a bit of the rear view namely showing about 25% of the rear 1/4.
Just my observations regarding sport mirrors, maybe the '77 and newer Corvette mirrors are longer? Never checked.
Oh yes, my remote cable was secured by plastic ties to keep from flopping around and you set the mirror by pressing on the corners. The trim panel was not cut.
Old May 2, 2013 | 01:35 PM
Easy Mike's Avatar
Easy Mike
It is my understanding Corvette sport mirrors are different from other GM makes (Carmaro/Firebird, etc). Heads are the same but the pedestals are different.
Sport mirrors are shorter overall than chrome mirrors.
Old May 2, 2013 | 01:48 PM
BDoc's Avatar
BDoc
Why anyone would ever want to replace chrome mirrors with the ugly sport mirrors is beyond me. I'm going through hell to swap mine the other way.
Old May 2, 2013 | 02:01 PM
v2racing's Avatar
v2racing
The same reason some like vanilla and some like chocolate!
Old May 2, 2013 | 02:17 PM
BDoc's Avatar
BDoc
But who would like vanilla over chocolate!??
Old May 2, 2013 | 02:40 PM
Shark Racer
Someone once tried to get into an argument with me because I said I didn't like guacamole.
I asked them if there was any food they didn't enjoy eating. They said yes. I said, OK, when I eat guacamole that's how I feel when you eat that food.
Old May 2, 2013 | 04:16 PM
Easy Mike's Avatar
Easy Mike
...Why anyone would ever want to replace chrome mirrors with the ugly sport mirrors is beyond me...
You're entitled to your opinion regarding sport mirrors, but Pete did not ask for opinions.
Why someone would leave a loaded weapon within reach of a five year old who then shot and killed his two year old sister with it is beyond me.
To About sport mirrors...
Old May 2, 2013 | 09:23 PM
DUB's Avatar
DUB
Pete,
Watch out when you do this. Several reasons but one of the major reasons is that the mirror will sit lower and make it really hard to see over the 1/4 panel. I have installed this type of mirror in the past...and I can tell you your side view will change due to height reduction.
Just thought you might like to know.
DUB
Old May 2, 2013 | 09:43 PM
Shark Racer
If you set your mirrors up properly, they shouldn't be trying to look over the quarter panel at all.
http://www.wikihow.com/Set-Rear%E2%8...te-Blind-Spots
If you're not following the advice above, it'll blow your mind when you get used to it. I started doing this a few years ago when I bought my first convertible. It kicks ***. No need to look over your shoulder. Hell, I barely even do that when backing up now.
Old May 2, 2013 | 10:14 PM
Peterbuilt's Avatar
Peterbuilt
Thanks everyone for the information, some of it made me laugh.
IE: trade the door panels. LOL!
Why would I go from chrome to painted?
For the same reason I bought a Corvette, just for fun!
Looks like the purchase of the 78 sport mirrors is off as I have not heard back from the seller, so I'm going to buy the #1600B and try to find some classic white in a can and spray them. Wish me luck.
Here's a picture of the chrome ones.
Will the white ones look better?
As far as adjusting the mirrors for blind spots, how about behind the sail panels?
