Console Side Panel question
Old May 5, 2013 | 08:22 AM
indydoug's Avatar
indydoug
Default Console Side Panel question
From the factory, did the side panels have a curvature or were they flat?
I just pulled the console side panels off as part of a carpet replacement, and as expected, they are in rough condition. They are curled in the top-to-bottom direction. They also have water stains, so I can't tell if they have been deformed from water damage.
I plan to remake them and need to know if I should use a material that will flex, or if something more rigid would work.
Old May 5, 2013 | 08:27 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
They're essentially flat. No need to make a pair when you can purchase replacements.
Old May 5, 2013 | 09:01 AM
indydoug's Avatar
indydoug
Thanks, Mike, for the prompt reply!
Depends on affordability!
Old May 5, 2013 | 09:41 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by indydoug
...Depends on affordability!...
It depends on the value you place on your time. You can spend half a day trying to make a pair, or you can order a pair and spend your half a day doing something else.
Old May 5, 2013 | 09:56 AM
indydoug's Avatar
indydoug
Good point.
Old May 5, 2013 | 01:25 PM
straitjacket's Avatar
straitjacket
i re made mine and it took all of an hour. i used 1/8 in paneling and recovered in black vinyl. . i just used the old ones for templates. .
billy
Old May 5, 2013 | 01:29 PM
stinger12's Avatar
stinger12
Which covers are you guys referring to?
Old May 5, 2013 | 04:07 PM
indydoug's Avatar
indydoug
These: http://www.ecklerscorvette.com/corve...1981early.html
To Console Side Panel question
