Shocks....
Old May 11, 2013 | 10:00 AM
Richard Cooper's Avatar
Richard Cooper
Default Shocks....
I want to replace the shocks on my 81. I am looking for a smooth ride, can anyone suggest a good set? Thanks.
Old May 11, 2013 | 10:30 AM
7T1vette's Avatar
7T1vette
Just buy any good brand name gas shock absorbers. Delco, Monroe, etc. will give you a decent ride.
Now, if you want good handling also, then you need to consider Bilstein "Heavy-Duty" shocks. Bilstein "Sport" shocks would be too stiff for you, I think.
Old May 11, 2013 | 11:19 AM
Shark Racer's Avatar
Shark Racer
Delco and KYB would be my suggestions, but Bilstein HDs are the best choice as mentioned.
I'd avoid Monroe, they last about as long as they cost.
Old May 11, 2013 | 11:26 AM
Street Rat's Avatar
Street Rat
Koni Sports here. 5 levels of adjustment. A bit pricey for most folks. Excellent ride quality and handling.
Old May 11, 2013 | 11:42 AM
qwank's Avatar
qwank
a word of advice: no matter what shocks you put in, you won't get a "Smooth ride". these aren't Cadillacs.
I just don't want you to get your hopes up and be disappointed after you change your shocks.
Old May 11, 2013 | 01:11 PM
Arkyvette's Avatar
Arkyvette
Monroes are probably fine for stock springs. I just put four on my 82. The front rides as expected but the rear is bouncy. I found that I have a VBP rear spring, 420# I think but the lablel is half missing.... If you have stiffer aftermarket springs on the car, you will might want better shocks to control them.
Old May 11, 2013 | 01:15 PM
Shark Racer
Any of the aftermarket leaf spring options will want a lot of rear shock. The stock 7-leaf (292-ish#) spring had some amount of built in damping from the friction between leaves. The composites don't. Monroes definitely will not cut it. You want, at a minimum, Bilstein Sports.
Old May 11, 2013 | 01:19 PM
Wrecked82's Avatar
Wrecked82
VB&P has KYB's that are valved specially for composite rear springs. Normal KYB's on front. Try them, you will like them.
Old May 11, 2013 | 01:22 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Ac Delco HD
Old May 11, 2013 | 07:14 PM
jdecarlo's Avatar
jdecarlo
Absolutely
Old May 11, 2013 | 07:28 PM
Paul L's Avatar
Paul L
That was my choice. Very nice ride with a #330 composite.
Old May 11, 2013 | 07:59 PM
MikeKey's Avatar
MikeKey
I have Bliestien Sport Shocks on the rear with the #330 composite, I like the rear. Switching the front to the mono-spring.
Old May 12, 2013 | 08:23 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...any good brand name gas shock absorbers. Delco, Monroe, etc. will give you a decent ride...
KYB would be a step up and a little stiffer. Bilsteins are over kill for a driver/cruiser.
Old May 12, 2013 | 09:24 AM
mk's78's Avatar
mk's78
Default I agree with qwank!!!!!!!!!!!!
qwank hit the nail on the head.....
I am using KYB's with a new rear OE spring and I still agree with qwank....
mk's78
Mike
Old May 12, 2013 | 10:10 AM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
The best riding shock I've used are definitely the KYB GR-2's (not the standard white ones - they are stiff). I loved them for cruising. Smoothest ride I've had in my vette; however they are not performance shocks. Great for cruising and trips!
If it was easier to switch shocks on these cars I would keep a set of KYB GR-2's around just for cruising, but since I use mine for alot of road course events I'm switching to Bilstein Sports. I have enjoyed my Eldelbrocks but I need something a bit more stiff now.
Old May 12, 2013 | 01:18 PM
Shark Racer
The stock base springs rode pretty nice IMO... 300 front/150 rear or so.
I've never actually owned a car that had them, I've always had the 550/300 pair (2 C3s), which ride "OK" at best.
Old May 12, 2013 | 03:48 PM
Mick71's Avatar
Mick71
St. Jude Donor '13-'14-'15,'21
I have Monroe gas shocks, and most people are surprised by the smooth ride of my car.
To Shocks....
Old May 13, 2013 | 05:03 AM
terrys6t8roadster's Avatar
terrys6t8roadster
the 6t8 has double adj QA1 and VPB's dual mount very firm, the 69 DD came with Monroe gasers in it rides very nice and don't see any need to change them, a friends 68BB installed KYBs and really likes them
Old May 13, 2013 | 09:59 AM
MikeKey's Avatar
MikeKey
Guess I'm the only person that thinks the Bilsteins are just fine for cruising.
Old May 13, 2013 | 11:50 AM
Shark Racer
I'd run the HDs for stock applications and Sports for the fiberglass rear spring apps, but I think they're completely fine for cruising.
I run them on every car I own; my C6Z and C3 have sports. The C6Z's have custom valving from DRM.
The shocks on my Avalanche are out-of-the-box Bilstein HDs. It's the best riding car I own by a wide margin; rivals my grandma's Benz (and may even be better.)
